Brighter headlights
Old May 1, 2004 | 02:55 PM
  #41
Vette X 3's Avatar
Vette X 3
Default Re: Brighter headlights (boodyman)
Cool! I did not realize the 4537 was the entire 5 3/4" Beam- I butt-umed it was just the lamp. I wonder if GE makes a similar-sized unit that is less intense than the 4537, but significantly more than stock. My luck I'd hit the highs by accident and they'd be so bright I wouldn't see the oncoming lights flashing until I saw them in the Rearview mirror!
Old May 1, 2004 | 03:00 PM
  #42
73 Vet's Avatar
73 Vet
Default Re: Brighter headlights (Ironcross)
I'm going for the best of both worlds; aircraft lights ( :cheers: thank you Ironcross) and, relays ( :cheers: thank you 7t2Vette). I like the idea of reducing the load, thereby increasing the voltage (less voltage drop), on the ignition and other accessories, as well as having killer brights. Thank you all. :D
Old May 1, 2004 | 06:07 PM
  #43
Wrecked82's Avatar
Wrecked82
Did some searching and see the GE4537 has a rated life of 25 hours. Hmmm.
The GE4537 is a 100W bulb. Found a GE4480 that is 60W, 5-3/4", with the two lug connectors.
Wattage of high beam stock is 37.5, of low beam is 60. I presume the higher low beam wattage is for when highs are on.
So, check out this link: http://www.asltg.com
The low beam has what is known as an A3 base (3 contacts), this high beam an A2 base (two contacts).
What you don't know is the dispersion of the lights - wide or narrow.
[Modified by Larry82, 5:48 PM 5/1/2004]
Old May 2, 2004 | 05:17 AM
  #44
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Brighter headlights (Larry82)
Great link Larry.... :cheers:
Here's what I found, If we are using the 4000 & H40001, Then this is the versions with matching plug, (A2-A3) and the size (par46) voltage (12.80).
4000 C6 A3 PAR46 12.80 37.500 200
4431 C6 A3 PAR46 12.80 45.000 160
4467 C6 A3 PAR46 12.80 50.000 320
H4467 A3 PAR46 12.80 50.000 320
4492 C6 A3 PAR46 12.80 60.000 300
H4001 C6 A2 PAR46 12.80 37.500 200
H5001 C6 A2 PAR46 12.80 50.000 200
4478 2C6 A2 PAR46 13.00 60.000 800
4480 2C6 A2 PAR46 13.00 60.000 800
Now to wait until monday to call and ask them if we are looking at this correctly.
Old May 2, 2004 | 09:08 AM
  #45
Wrecked82's Avatar
Wrecked82
Default Re: Brighter headlights (Desertdawg)
Let us know what you find out. Was going to call them also. No need for two to call.
For those who have not gone to the website the layout of the info in Dawg's post is:
Bulb number
Filament type
Connector type
Size of light (5-3/4 sealed beams are Par 46)
Cost
Watts
Life
Dawg has given the low beam and high beam stock numbers (4001 and H4001) followed by possible choices.
Dawg: Vendor might tell you they are not for automotive purposes, we just need to get around that comment if they say that.
[Modified by Larry82, 1:17 PM 5/2/2004]
Old May 2, 2004 | 10:55 AM
  #46
75 BBC Stingray's Avatar
75 BBC Stingray
Ironcross
With these lights being of higher wattage, are there any concerns about additional heat being generated?
Old May 2, 2004 | 11:09 AM
  #47
Vette X 3's Avatar
Vette X 3
Next to last number is AMPS rather than wattage according to the chart, but I find this hard to believe. I think you are correct that this is watts-not amps. Talk about voltage sag! :confused:
Old May 2, 2004 | 05:38 PM
  #48
Pete76Shark's Avatar
Pete76Shark
I have been a Pilot since 1990 and I can't for the life of me figure out why I did not come up with the landing light for a high beam idea... But it is a great idea for sure and I have 2 on order now.
I will also do the headlight relay mod as this will get 14 volts to all 4 headlights.
In my opinion, while landing at night with the landing light on (we have to do it with and without) I would say the landing light is a flood light and not a spot light. Which would be a wide bean and not a narrow beam.
a Pilot does not need to see down the runway, he needs to see within 50 yards in front of the plane and he MUST see to the sides. So this would lead me to say that the landing light is a flood (wide beam) light.
Anyway, I got 2 on order and I will do the headlight relay mod from scratch parts, actually 2 horn relays or any 12 volt coil relay will do the trick.
This discussion has been great. Thanks to all for sharing your ideas.
:steering:
Old May 2, 2004 | 07:43 PM
  #49
Wrecked82's Avatar
Wrecked82
Default Re: Brighter headlights (Pete76Shark)
Check out this information. Limited in number of applications, but it has the horizontal (meaning, distance in front of car) and vertical (height of the beam). The 4537 has a very short horizontal measurement (11ft) vs. the stock 4001 (34ft). So, it is a flood rather than a spot. Other applications seem to be a better alternative.
Old May 2, 2004 | 07:44 PM
  #50
Wrecked82's Avatar
Wrecked82
Here is the link, since that picture is too small.
http://www.dee-inc.com/netstore/cata...oductCode=4537
[Modified by Larry82, 6:45 PM 5/2/2004]
Old May 2, 2004 | 08:07 PM
  #51
Pete76Shark
200,000 candle power vs 55,000
Thats some flood light
[Modified by Pete76Shark, 8:10 PM 5/2/2004]
[Modified by Pete76Shark, 9:18 AM 5/3/2004]
Old May 2, 2004 | 10:48 PM
  #52
Ironcross's Avatar
Ironcross
I though I was done with this thread but some doubts apparently has come up as to the longevity and lighting ability of 4537`s. So in defense of my choice of lights. I believe that they are standard equipment in my 210. Never burned one out yet so I`m not 100% positive of that fact. So far, no replacements in my 62 or 68 Vettes in well over 35 years. And to the lumination of 200,000 candlepower on the highway, I can light up those roadside reflectors on I-75 for a couple of miles on my way to Boyne Mountain. No fancy relays or any other add on junk. My light switchs handle the increased heat without any problems and I guarantee that you cannot out drive them at any speed. Most light general aviation aircraft land at around 80 mph depending on where the flaps are set and the FAA wouldn`t allow bad lighting on a aircraft. I like them, but as you can read from the posts, they are not for everbody. :D And in closing, I`m now ready for a Cohiba and a Corona. :cheers:
Old May 2, 2004 | 11:04 PM
  #53
71coupe's Avatar
71coupe
Here's some landing lights for ya :D
[Modified by 71coupe, 11:11 PM 5/2/2004]
Old May 2, 2004 | 11:52 PM
  #54
GDaina's Avatar
GDaina
Default Re: Brighter headlights (71coupe)
You lose the fiber optics because the backside of the hellas is metal.
Ahhhh....learn something new....
Old May 3, 2004 | 12:00 AM
  #55
GDaina's Avatar
GDaina
I'll join ya, Corona con lima..... :cheers:
Old May 3, 2004 | 01:45 AM
  #56
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I wasn't doubting you, I just had fun looking for a suitable setup that might match the factory plug, and also the chance of finding a bulb for the low beam.
I'm going to call them tomorrow, and NOT tell them what I want to use them for. Hopefully we can find some suitable replacements. :thumbs:
Old May 3, 2004 | 10:08 AM
  #57
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Great post, now I need to run to Wal-mart and return my high-beam purchased last week for some of those landing lights. :D
To Brighter headlights
Old May 3, 2004 | 11:14 AM
  #58
Wrecked82's Avatar
Wrecked82
Ironcross - I wasn't doubting you either. I am just eternally curious about things and stumbled onto this info. Only a layman, so just trying to sort things out also. I was wondering about the 25 hour life, which seemed ridiculously low that they would not be practical, airplanes especially. So, guessed the actual life would be longer. Don't usually drive long periods of time with the highs on anyway. This thread has been one of the more interesting for me as its something I can get my pea-brain around w/o too much effort.
Old May 3, 2004 | 11:46 AM
  #59
Touringpro's Avatar
Touringpro
. . . go to Http://www.airsuppliers.com Click on lights, then enter the part #. The part # is GE 4537, 13 volt lights. $14.95. . . .
Whaaaat???? Unless I'm missing something here (always a strong possibility :D ) the shipping charges from these people are outlandish. I went to their website to order a couple lights - $29.08 total - and for this they want at least $21.18 for ground freight and up to $50.17 for Next Day Air!
Is this really the case or do you guys see something I don't? :confused:
Old May 3, 2004 | 02:55 PM
  #60
BB68Vett's Avatar
BB68Vett
Default Re: Brighter headlights (Touringpro)
I haven't looked but I don't doubt it. Many of these places draw you in with a low price and then hit you with outrageously high shipping and handling fees. I saw another sight that had the GE 4537 for $36.08. Not sure of the shipping though.
