Tachometer, voltmeter,not working HELP !!
Old May 2, 2004 | 01:46 AM
drsleep's Avatar
drsleep
Default Tachometer, voltmeter,not working HELP !!
My tach, voltmeter went out and the battery and choke light came on while I was driving. I have checked all fuses and checked alternator, all good. They were working fine and just went out, 1981 corvette any help ?
Thanks :beatdeadhorse:
Old Jan 9, 2018 | 02:48 PM
Corey Frith's Avatar
Corey Frith
1st Gear
Default Tach and volt meter
did you find a fix by chance I’m having the same problem
Old Jan 9, 2018 | 06:29 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
choke light? did it come unplugged?
interesting things that went off.
do you have a wiring diagram?
at this point i can't see a link between tach and volt meter.
quess check where the wires run and see if they got cut, pinched, or grounded.
Old Jan 9, 2018 | 06:58 PM
DUB's Avatar
DUB
Without me having my wiring diagrams here at the house...I would guess that you lost power...especially to the CHOKE relay
I need to look a wiring diagram to clarify or further advise...so i might bring it home tomorrow.
DUB
To Tachometer, voltmeter,not working HELP !!
