Pulsating Brakes
Old Jun 26, 2004 | 12:41 PM
USA SHARK's Avatar
USA SHARK
Default Pulsating Brakes
The project continues......
I finally finished all of the supension rebuild and power steering rebuild (and it doesn't leak any more!! Although they did initially until I taped the threads on the P/S valve)
The front rotors looked pretty bad, so I took them in to be turned and they had to grind off quite a bit, but they said it should be ok. After installing them and putting it all back together with new brake pads, they now work but pulsate pretty heavily when I apply the brakes.
Is it possible they took too much off or they still are warped? If so, I guess the only alternative is to replace them. Any way to replace the whole hub and rotor without spending a fortune? (One of the studs is broken on one side in the front, and one is loose in the rear but not broken)
One thing at a time...
Old Jun 26, 2004 | 01:00 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Default Re: Pulsating Brakes (USA SHARK)
Sounds to me like they are still warped...
Old Jun 26, 2004 | 01:54 PM
w1ctc's Avatar
w1ctc
I had one rotor that had a hard spot. The pad would polish that one
spot and then slip over it making the pedal pulsate.
Old Jun 26, 2004 | 02:30 PM
Mike Ward's Avatar
Mike Ward
If you had the rotors turned separate from the hubs, that's most likely your problem. They must be turned as a matched set. C2/C3 disk brakes cannot be maintained the same way as other cars.
Old Jun 26, 2004 | 06:48 PM
USA SHARK's Avatar
USA SHARK
Default Re: Pulsating Brakes (Mike Ward)
They were turned with the hubs, but I know there were a couple of tough spots he told me about. They weren't sure they could be turned, one spot was black. I think they just need to be replaced.
Thanks for the input.
Old Jun 26, 2004 | 11:35 PM
w1ctc's Avatar
w1ctc
Try NAPA, $30 each and made in USA.
To Pulsating Brakes
