common headlight problems
Old Jun 27, 2004 | 03:05 PM
1973stingray's Avatar
1973stingray
3rd Gear
Default common headlight problems
I just got my first vette and I am very excited about it. I assume that the vacuum operated headlights are a common problem area. Mine won't come up by themselves but they go down fine. Any suggestions for a fix would be appreciated. Thanks for help
Old Jun 27, 2004 | 03:17 PM
Larry B.'s Avatar
Larry B.
Default Re: common headlight problems (1973stingray)
Check out http://www.corvettefaq.com There is lots of info there on almoct any topic. Great site for a necomer. This forum is also a terrific site for knowledge and help. If you have a problem,chances are someone has "been there,done that".
Old Jun 27, 2004 | 03:38 PM
zwede's Avatar
zwede
Not going up, but going down fine is usually an indication the actuator seals have torn. Fairly easy DIY fix. You can get the seals from any of the vette vendors for about $10 or so. Get the kit that includes the holding plate and dust cover.
To common headlight problems
