Can we now split the C-3 site, please.....
i'm still waiting for an explanation of the pancake thing and the badger thing.
One of those things that you either think is funny or you don't, you can't explain it. Sorta like Bevis and Butthead.
Splitting the forum into three or more sections would indeed make it clunky and time consuming to navigate. Two forums on the otherhand seems wise.
*General
*Performance
Let the restoration guys decide which to post in.
Simple and clean.
Where is the line drawn between Tech and General? It seems to me that most posts would belong in Tech and a minority would be in General. So much of what we post is Tech-related. Fixing this or that. Why is this or that happening. Which cam. Which heads. etc....
Tech is real tech stuff so no carpets, wheels and whatever. It doesn't have the be outlined very specifically as to what is tech and what not, posts won't drop off very quickly and just the split alone will cure most of the problems.
My findings, in short:
General: 31
Tech: 36
Even if I'm off by 5 posts to the "General" forum, that would still put it at a 26/41 (or 39%/61%) which would give about a 2 - 3 day turnover on the first page of the C3 General Forum. Hardly enough to cause a forum to go stale.
Here is how I classified them. I, so here they are:
General:
KYB GR-2's --NICE!
NCRS T-SHIRTS!!!!!! (TRUE?)
Anybody running 4:10s on street
VanSteel running special?
dealer manual for a 77
Anyone Have C3 Crossed-Flags For Desktop
Post pictures of new interiors please
Looking for choke plug
hehehehehehehehe
I just go My new toy 1972 Corvette
invisible black corvette
fun with pep boys/autozone/strauss
Overhaulin does a '64 tonight on TLC
Warn bystanders that are too close?
Dyno testing in Ft Myers...how did it go?
From Sarasota Sam The Wheelaholic And Handbrake Man!
This thing's a beater, but I like it.
Vette Viewing needed in Galveston Please
extra guage location
[POLL] What oil are you running??
Couple of pics of my new 18" Boyds
At last my supercharged baby is finished!
How much $$ do you have into your Vette?
? 82's with OEM Charcoal interior
Possible trying to sell, help me priice it please..
Losing It?
Just finished my car...
Did the Hooker-Jet Hot Coatings sidepipe deal go away?
It started with me wanting to clean up the console.......
Looking for some pricing help (not dialup friendly)
Canadian Vette
Tech:
Looks like it is motor mount time!
Radiator Removal - 72' 454 with AC and 4spd
Converting to manual steering? ( 1 2 )
69 Big Block Pulleys- Help Please
Auto trans won't shift out of 1st!
Please help identify loose vacuum hoses and wires
Carb spacers, any test results???
Mod Question - Rocker Switch Controls
carburator and exhaust question.
Looking for thermostat advice
Demon fuel line connection?
Side yoke and posi questions...
Intermittant Starting
aerodynamics question
Vette ring and pinion type-12 bolt?
Where is the front brake caliper Bleeder valve???
AMSOIL vs Mobil 1 (although I imaging this would have been spammed on both)
Suspension question
78 SMOG/A.I.R question
T-10 side cover gasket
Many Lessons Learned Today!
Working with metal braided hoses
What size are the seat belt bolts?
AC fan - Need more volume on a '78
Fusible links???
what does the correct 69 wiper washer tee fitting look like?
How low is my car??
I need some EXPERT engine part help (rod bearings)
632" Big Chief: pics
Is it normal?
What is with the wiper door?
Bypass the tach filter?
Has anybody used Spicer Chassis parts?
81 Vent Cover Passenger Side
Wiper Switch Bezel
Rubber Gaskets and RTV Sealant
General: 31
Tech: 36
This topic has come up many times before, and each time, there has been an overall opinion that maintaining a single section was the best option.
At this time, the best I can say is that we'll consider it. There are pros and cons to a split to say the least.
One thing I have been thinking of, and this isn't specifically in response to Chris' post, is what about a FAQ section? Something much like the corvettefaq website, but here on the forum. Granted, I've been here for 5 years, but a LOT of topics come up somewhat frequently. Having a compilation of those in a separate section, labeled as such, might help out. It'd be possible to maintain the section to add relevant information to old posts as necessary. I'm thinking more about a section of locked posts, but I'm not sure that would be the best way.
i know that I, for one, will come here less...
anybody else feel this way too???
As I posted earlier the reason I don't go to the other forum as often as this one is because they split theirs.
A maintained FAQ would sure cut down on the repeat posts.
Yes lock the threads, and then maybe we can get the members with the best solution to re-write the topic to be like a tech page, and then include the best replies to top it off.
http://forums.corvetteforum.com/showthread.php?t=863574
as far as splitting being the death of the forum, a lot of knowledgeable people have already left and I fear it's because of all the crap posted that makes the forum like struggling through a jungle.
Heck I'll TTT it for him for the next 3 days for a buck a day. $$$$
Re-tuned CFI system.
Polished rims.
Complete tune up W/wires thru motor mounts.
Replaced all weatherstripping.
Re-bent rear hatch struts.
Found replacement gas struts for hatch.
New radiator.
Electric antennae repaired.
And yes, new tail light bulbs.
I have tried to add useful information to every post I can. and yes I try to have some fun too.
I have spent hours looking for parts when the new members (& some old members) come asking for them, because I seem to do good with web searches.
I also read most technical posts, I don't always reply, because I have only owned an 82, but it sure is fun learning what I can about the other 13 years of C3's out there.
But what I have learned is that I really love figuring out how to fix my own problems with research, then if someone comes up with the same problem, I can jump in with what I learned.
But I also like to have FUN !!!
I don't think this is a good post to base your splitting the forum up with. he had plenty of opportunity to TTT it himself with more questions. Why no one responded to it is going to never be answered, it's just the way the forum crumbles.
Honestly, I get 99.6% of what I NEED from the search. I would LIKE to post more in reply to other threads, but having to weed through the non-tech stuff puts me off. I used to spend my luch hour reading and posting on pretty much a daily basis with no problem keeping up. Now, I can't do it and just find myself frustrated sorting through stuff I'm not interested at all and not making it back to where I left off.
I do admit, though, the "preview" thread helps in this regard.
no sense in actin all spotty and puffy...
