brake master cylinder
Old Jul 20, 2004 | 12:30 AM
Schmucker's Avatar
Schmucker
Yes, I'm making my own power bleeder out of an old MC top and an air fitting. I'm having a very similiar problem, except I have brakes for the last inch of travel and I get a good firm pedal with the engine off (no assist) but only that one inch with it on. And after a bleeder is opened I have to pump the pedal to get that inch back. I replaced the MC and bled everything. I'm going to try power bleeding and rebleeding the MC. Does it sound like a bad booster? The pedal gets easier to push with the engine on, it doesn't make sense to be the booster.
Old Jul 22, 2004 | 04:08 AM
saudivette's Avatar
saudivette
Righto guys, the day has dawned! I picked up a new booster yesterday and am going to fit it today, once the temperature drops below 50 degrees C!!
While I had my old one out, I pushed on the rod (that attaches to the pedal) and it was very soft and spongy and made some weird clicking noises :*****
The new booster I have, I can barely move the rod and no extraneous noise come from it when I do...
I'll let you know if it fixes my brakes
Old Jul 22, 2004 | 09:31 AM
wcsinx's Avatar
wcsinx
Yeah, you really shouldn't be able to push that rod (by hand) much at all. Hopefully that's your problem.
Old Jul 22, 2004 | 03:03 PM
wcsinx's Avatar
wcsinx
Hey! It just occurred to me that you have the opportunity to solve the mystery. Do you still have the old booster, or did you turn it in for a core? If you have it, would you be willing to saw it in half? Maybe that could shed some light on the mysterious sinking pedal-bad booster problem.
Old Jul 23, 2004 | 03:14 PM
saudivette's Avatar
saudivette
Righto guys, I think I can explain the booster problem... I bought a new booster, but the push rod that attaches to the brake pedal was different. The guy in the shop had the guts from the new one put into my old shell with my push rod. While it was in bits, I had a bit of a squiz and the guy tried to explain what was wrong.
The diaphragm (yellow) was ruptured, the reaction plate (red) was corroded to almost nothing and the return spring was broken. When the push rod (purple) was being pushed, it had to travel (unassisted) all the way to meet the master cylinder push rod (blue), before any braking began to take effect. As the diaphragm was ruptured, it was left to the broken return spring to try and push the pedal back to it's "normal" position when you took your foot off the pedal. Does that make sense?
Old Jul 23, 2004 | 03:20 PM
saudivette's Avatar
saudivette
In my case, I can see why the pedal was spongy and why the pedal went nearly all the way to the floor...
Old Jul 26, 2004 | 09:25 AM
wcsinx's Avatar
wcsinx
Well there we have it. If the so called "reaction plate" rusts away then the booster can very well be the cause of the pedal sinking to the floor. How are your brakes now?
Old Jul 26, 2004 | 10:53 AM
zwede's Avatar
zwede
Yeah, I'm curious also if replacing the booster fixed it. I kind of felt like the guy reporting little green men...
Wondering why the "rebuilt" booster would have that symptom... Maybe the rebuild was so crappy they didn't replace a rusted out reaction plate????
Old Jul 26, 2004 | 01:04 PM
wcsinx's Avatar
wcsinx
Wouldn't surprise me a bit if the rebuild only replaced the rubber parts.
Old Jul 26, 2004 | 02:13 PM
saudivette's Avatar
saudivette
I still need to bleed the brakes but even now are a zillion percent better. pedal doesn't sink any more and the faint hissing noise from under the dash has gone away...
Old Jul 26, 2004 | 03:36 PM
zwede's Avatar
zwede
Old Jul 26, 2004 | 03:38 PM
wcsinx's Avatar
wcsinx
You should have mentioned the hissing noise in post #1. That's a sure fire sign of a bad booster.
Glad it's working (better) for ya.
