Vibration damper
Old Jul 20, 2004 | 02:14 PM
74Thrasher's Avatar
74Thrasher
Default Vibration damper
Howdy,
Can anyone tell me where the vibration damper is located. I found the timing tab, but the Chilton's makes absolutely no mention of where the vibration damper is. I'm attempting to reset my timing, and the location of that stupid dampes eludes me. Thanks,
- Colin
Old Jul 20, 2004 | 02:20 PM
Twin_Turbo's Avatar
Twin_Turbo
??? is this serious? the damper is on the crank with the pulleys in front of it, in fact the pulleys bolt to the damper. When you look at the timing tab, the thing under it is the damper:
timing tab w/ damper: (this is not stock, yours will look different but it's just to give an idea.. this is my homebrewn bubba timing pointer solution for cheap skates)
JB's Avatar
JB
St. Jude Contributor
You mean the harmonic balancer/dampner? That's the big round thing right underneath the tab. Or am I misunderstanding?
JB
Old Jul 20, 2004 | 02:30 PM
Garrett1972's Avatar
Garrett1972
JB
BINGO, you got it
Old Jul 20, 2004 | 03:13 PM
wcsinx's Avatar
wcsinx
How the HELL can you find the timing tab but not the damper? Dude, step away from the car.
Old Jul 20, 2004 | 03:16 PM
Fevre's Avatar
Fevre
:shocked:
Sorry, just had to get a shot in myself.
Old Jul 20, 2004 | 03:36 PM
GDaina's Avatar
GDaina
Easy guys...give the newb a break....
Old Jul 20, 2004 | 03:51 PM
74Thrasher's Avatar
74Thrasher
Holy god, guess I am never asking a question here again. Had the car for about a week, never worked on an engine in my life before, and like I said, the Chilton's manual doesn't have a picture of it. Man, some of you guys are asses.
Old Jul 20, 2004 | 04:00 PM
Twin_Turbo's Avatar
Twin_Turbo
well.. but that question was kinda asking like " I found the doorknob but where is the door" ...sorta
Old Jul 20, 2004 | 04:03 PM
wcsinx's Avatar
wcsinx
You're going to have to grow a thicker skin if you want to hang around here for any length of time. If you'd said the above right off the bat, the replies would have been more user friendly I'm sure. Don't run off just yet. This forum is a wealth of information for all things Corvette.
Old Jul 20, 2004 | 04:04 PM
wcsinx's Avatar
wcsinx
*snort*
Old Jul 20, 2004 | 04:06 PM
Twin_Turbo's Avatar
Twin_Turbo
trasher should go toughen up in OT, I don't even go in there without my asbestos suit
Old Jul 20, 2004 | 04:11 PM
GDaina's Avatar
GDaina
That's one thing that's not tolerated.....calling people names...you have to have a thicker skin if you want to hang with this group...
Don't take it personal, the guys were only having fun at your expense.
Old Jul 20, 2004 | 04:14 PM
74Thrasher's Avatar
74Thrasher
My skins's fine, I just don't see the need for flaming something that isn't THAT obvious. The manual says to look for a groove in the vibration damper which was nowher in sight (I ended up have to look from the underside to find it) so there was really no way for me to know where it was.
Old Jul 20, 2004 | 04:17 PM
Twin_Turbo's Avatar
Twin_Turbo
but you said damper, not the groove in the damper.
Seriously, if the groove is nowhere in sight the damper has slipped and you need a new one.
Old Jul 20, 2004 | 04:21 PM
74Thrasher's Avatar
74Thrasher
Well that's what threw me off, because I didn't see the groove. The damper is circular and the groove just happened to stop where I couldn't see it. Or is the groove always supposed to be on the top in aligment with the timing tab?
comp's Avatar
comp
i does help to add your abilitys, mine ain't spellin' we all throw
things in fun on this forum... you just roll with it
To Vibration damper
Old Jul 20, 2004 | 04:25 PM
Twin_Turbo's Avatar
Twin_Turbo
you need a timing (strobe) light to adjust the timing. When all is well and the light is hooked to sparkplug wire #1 (inductive pickup) it should flash with the groove somewhere near the timing tab and if you set it right it will sit at the amount of degrees timed in, or at 0 if you use a dial back light and set it to the correct amount of degrees.
Old Jul 20, 2004 | 04:44 PM
74Thrasher's Avatar
74Thrasher
So like in this picture, the groove sits right on the timing tabs. After I turned my engine on the last time, the groove moved to a different spot altogether. Does that mean the damper needs to be replaced?
Old Jul 20, 2004 | 04:51 PM
Twin_Turbo's Avatar
Twin_Turbo
uhm??? the damper turns because your crank turns. If your engine runs the damper is turning at crankshaft speed. that's why you need a strobe light, so that it fires when the crank is in the right pos (cyl #1 igniting) and it will appear as a still picture of the groove against the timing pointer.
I suggest you do some reading on howstuffworks.com before attempting to set the timing, and this is not making fun I'm dead serious here.
In my pic the groove is at the correct position because I set the cyl #1 to top dead center to stab the dizzy and to fab the pointer so it would accurately read in the correct degrees (the sharp pointy thing is the pointer from the gear drive and as you can see it's not only off, it's also very hard to read properly being that far away from the damper)
