power master mini starter hookup
Old Jul 24, 2004 | 01:03 PM
mikesfst69's Avatar
mikesfst69
Default power master mini starter hookup
I am trying to hook up powermasters ministarter up it only has two terminals out of it I understand one hooks up to the positive of the battery cable and the other smaller one hooks up to the key switch and isnt there another wire from the key switch that hooks up to the negative of the coil, I am running a msd billit dist. with blaster 2 coil the dist has a harness with only black for ground and orange for the negative side of coil and red for the positve I know this is right, but any help for the other would be great
Old Jul 24, 2004 | 10:46 PM
wombvette's Avatar
wombvette
On the original starter there would have been a wire from the outer most terminal marked R that went back to the coil. It goes to the positive side though. That is the bypass circuit to add 12 volts during cranking. You souldnt need that for the electronic system.
