Dimmer Switch
Old Jul 25, 2004 | 06:32 PM
ICEMAN59's Avatar
ICEMAN59
Default Dimmer Switch
I NEED TO CHANGE THE DIMMER SWITCH ON MY 1980 IT'S ON THE COLUMN ANBODY DONE THIS?
Old Jul 25, 2004 | 11:04 PM
Jim Shea's Avatar
Jim Shea
All the information that you need to just replace your dimmer switch is in the following papers. It is probably easiest to drop the steering column so that you have access to the nut and the screw that holds it in place. This paper will walk you through dropping the column and replacing the dimmer switch. Don't worry about the steering wheel or the other switches. Disconnect your battery before working on your steering column.
This paper describes everything you need.
http://www.corvettefaq.com/c3/T&TColumnD&R226JA04.doc
This paper has some pictures that will help.
http://www.corvettefaq.com/c3/T&TDisasmInstrPage3.doc
Old Jul 27, 2004 | 06:37 AM
ICEMAN59's Avatar
ICEMAN59
thanks for the links they helped tremedously
Old Jul 27, 2004 | 07:34 AM
Jim Shea's Avatar
Jim Shea
Did you drop your steering column? Or were you able to replace and adjust your dimmer switch with the steering column in place?
Jim
To Dimmer Switch
