Pull Torque Converter and replace front seal?
Old Jul 26, 2004 | 10:34 PM
eddadams's Avatar
eddadams
Default Pull Torque Converter and replace front seal?
I have the engine out of my 75, the transmission is still in with blocks of wood holding it up. The torque converter is still in it. How hard is it to pull the torque converter and replace the front seal on the transmission while everything is out of the way? Are there any special tools required to pull and replace the seal?
Old Jul 27, 2004 | 07:01 AM
redwingvette's Avatar
redwingvette
It isn't hard but can be messy. The convertor will just pull out and the seal can be removed with a screw driver. Just be careful not to damage the surface. The new seal can be tapped into place with a block of wood and a hammer.
Old Jul 27, 2004 | 09:48 AM
comp's Avatar
comp
and lube seal and conv. snout when you put back in
Old Jul 27, 2004 | 10:19 AM
markdtn's Avatar
markdtn
Fill the back side of the new seal with white grease so the little spring doesn't pop out when you put it in.
Old Jul 27, 2004 | 01:40 PM
Kid Vette's Avatar
Kid Vette
Make sure you spin the convertor when reinstalling to fully engage it with the pump. You should hear/feel 2 "clunks".
Old Jul 27, 2004 | 02:00 PM
Tominator's Avatar
Tominator
Pour a quart of tranny fuild in the convertor before reinstalling it. Do this so it full at start up.
Old Jul 28, 2004 | 09:19 PM
eddadams's Avatar
eddadams
Thanks for the information guys, I will give it a try. I couldn't log on last night, I kept getting Server Busy.
To Pull Torque Converter and replace front seal?
