Front End Rebuild Kit
Old Jul 28, 2004 | 02:01 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Front End Rebuild Kit
We have front end rebuild kits on sale now if any of you are interested. You can check the link
http://www.vansteel.com/index.cfm?fu...&SubGroup=1864
Part number's FSK-01D & FSK-01DP are the 2 kits on sale. If you want to order on-line, shipping will apply BUT we will cut you a check for the freight since you are forum members. Got any questions, please feel free to e-mail me or call me at 800-418-5397
Dan
Old Jul 28, 2004 | 02:18 PM
wcsinx's Avatar
wcsinx
So I can get the poly front end rebuild kit for $180 flat? No shipping? Correct? Are you doing this instead of the group buy that you hinted at awhile back?
Damnit, I've blown my Corvette budget for awhile, but this just might be too good to pass up.
Old Jul 28, 2004 | 02:20 PM
comp's Avatar
comp
blown budget whats that
Old Jul 28, 2004 | 02:29 PM
NHvette's Avatar
NHvette
I installed the poly kit from Dan.
I haven't driven it yet, but the items were good quality.
One problem I had was a missing 'bumper bolt' that holds the
lower ball joint on the side. I messaged Dan, and he had one
out the door that day. Good parts, great service, and decent price.
Oh - I did find the tie-rod boots to be cheesy, but that
is a common problem - not Van Steel. I cleaned up the originals to reuse.
I'll bet dollars to donuts that half the folks out there with C3s
need this kit, but don't realize it (yet).
While you're at it, consider 460 front springs, or cut your stock
springs down a bit. Stock springs need a compressor, or you
will be wrestling them in.
Old Jul 28, 2004 | 02:40 PM
Van Steel's Avatar
Van Steel
Thats correct and if you order on-line we will refund you for shipping. If you live in FL you still have to pay tax. I can't do anything about that.
Old Jul 28, 2004 | 02:53 PM
wcsinx's Avatar
wcsinx
Originally Posted by NHvette
I'll bet dollars to donuts that half the folks out there with C3s need this kit, but don't realize it (yet).
Oh believe me, I know I need it. The popping and creaking up front everytime I turn a corner is enough to tell me that.
Yeah I was going to put new springs in there while I was at it. My car has the infamous left hand C3 sag. It got a lot better when I put a new rear spring in it. Hopefully new fronts as well will level me out.
Old Jul 28, 2004 | 02:55 PM
wcsinx's Avatar
wcsinx
Ehh, $11 more ain't gonna break the bank anymore than it already is. So should we just call the number you posted if we want to avoid absorbing shipping up front?
Old Jul 28, 2004 | 02:57 PM
Van Steel's Avatar
Van Steel
However you guys want to handle it. I'm here all day so I don't mind the phone calls.
Old Jul 28, 2004 | 04:02 PM
Fevre's Avatar
Fevre
Awesome timing, just started to tear my front end a part for a rebuild. How long is this special running? I am on a slow plan since my road is getting redone right now and that will take a while.
Old Jul 28, 2004 | 04:14 PM
Van Steel's Avatar
Van Steel
The sale will be good until the end of Aug. I will also be putting more items on sale.
Old Jul 28, 2004 | 04:20 PM
Fevre's Avatar
Fevre
Old Jul 28, 2004 | 04:34 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Good deal, just took most of mine apart already.
Old Jul 30, 2004 | 11:16 AM
machineg's Avatar
machineg
Default I just ordered mine
I just ordered mine, I cant wait... I also ordered springs, wooo hooo
Old Jul 30, 2004 | 11:28 AM
Van Steel's Avatar
Van Steel
Thanks Machineg
Old Jul 30, 2004 | 04:19 PM
Evil_1979's Avatar
Evil_1979
Damn- did mine already. You need to put the control arm poly bushings/rear spring/bolts/stainless shims on sale cus the rear end needs some help next!
Old Aug 2, 2004 | 09:20 AM
Van Steel's Avatar
Van Steel
I will definetly keep it in mind. Thanks
Old Aug 4, 2004 | 11:46 PM
EVIL_GRIM's Avatar
EVIL_GRIM
probably not the place to post this, but on a scale from 1 - 10 how hard is it to redo the front end with the kit your selling Dan? im familiar with all the fornt end components just never done it b4.
To Front End Rebuild Kit
Old Aug 5, 2004 | 08:27 AM
Van Steel's Avatar
Van Steel
I think you'll find that the hardest thing to do is to remove your old a-arm bushings. Sometimes they can be a real pain. There are write ups on how to's. On a scale from 1-10 I would probalby give this job about a 3 or 4. Maybe a 5 if your not a novice.
Old Aug 5, 2004 | 03:04 PM
Evil_1979's Avatar
Evil_1979
I agree with Van Steel- not hard at all.
I had never worked on any suspension before. Did the complete front end rebuild (all control arm bushings, ball joints, tie-rod ends & springs) including sand blasting and painting all 4 control arms and new calipers in two days.
Granted, I did have my dads help who is a regular on working with suspension- but I did all the work- he helped me out when I got stuck. I would not have had much diffuculty doing it without his help though- probably would have taken a while longer.
Hardest part was indeed removing the old bushings- and getting the stubborn ball joints to let go. Once I used a torch to burn out the old bushings it wasn't too hard.
Two days (not even close to 9-5) and it was ready to go to the alignment shop!
~K
Old Aug 5, 2004 | 06:17 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Did my front end with Van Steel parts about 3 months ago, and it's not bad at all. BUY THE VIDEO FROM VAN STEEL. None of the manuals I looked at helped at all, but the video makes life way easier. Best $20 or so you'll ever spend on your front end.
