Shifter Problems
Old Jul 31, 2004 | 12:35 AM
i885744's Avatar
i885744
Default Shifter Problems
I have recently installed a shifter rebuild kit in my 73. The 4 foreward gears work absolutely flawlessly. I couldn't be happier. However, when i pull up on the t-handle it won't go into reverse. If you hold the t all the way up it shifts in and out of first and someimes into a sort of "mystery gear" next to 2nd. I"m pretty sure something didn't go back together correctly in the shifter. What do you guys think?
Old Jul 31, 2004 | 12:39 AM
comp's Avatar
comp
get under and have someone use and watch it
