hood insulation question.
Old Jul 31, 2004 | 03:50 PM
i885744's Avatar
i885744
Default hood insulation question.
I know there is a problem with paint blistering due to engine heat if you don't run the hood insulation. I've got a small block with a weiand stealth intake and a demon carb. I also have the L-88 hood, there is pleanty of room between carb and hood. Should I even be worried about not having insulation? The underside of my hood is black, the topside dark blue... THanks, Mike
