Tilt-Tele column question
Old Aug 2, 2004 | 09:38 PM
scotty13's Avatar
scotty13
Default Tilt-Tele column question
The car is a 75'
My til-tele column is loose. it moves arround when it is in the locked position. Are there replacement parts available for this? it is the top two main moving pieces.
is there a coulmn that can act as a replacement in any other cars?
scott
Last edited by scotty13; Aug 2, 2004 at 09:41 PM. Reason: needed addition of words to description of problem
Old Aug 2, 2004 | 10:29 PM
carl a's Avatar
carl a
there should be some bolts that you have to tighten up ,,i had a chevy van that did this and it is dangerous(my mechanic tighened them up for me so i really dont know exactly where there located-someware on the column) if they loosten too much , tighten them up or get them tightened!!
Old Aug 2, 2004 | 11:07 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Interesting.... be careful.
It was my understanding when the column is loose that the bearings are failing and the integrity of the steering system is at risk.
I have the same issure with mine....
Mark
Old Aug 3, 2004 | 09:25 AM
Jim Shea's Avatar
Jim Shea
First, make sure that your steering column is mounted properly in your car. There are two vertical bolts right under the dash and the two nuts (down on the floor pan by your feet). Rock the steering column by the steering wheel, inspect the connections and make sure that they are tight. So now you know that the problem is in the steering column and not just loose connections.
The following link will take you to a paper that describes some quick and simple tests that you can perform on your T&T steering column to determine the source of your looseness, lash, rattle, etc.
http://www.corvettefaq.com/c3/T&TColumnD&R113MR04.doc
There are a series of papers, pictures, blowups, and steering wheel information that is posted at the www.corvettefaq.com websight. Between the papers and this forum you should be able to fix your problem.
Old Aug 3, 2004 | 04:42 PM
scotty13's Avatar
scotty13
Is there a coulmn from any other chevys that will fit as a direct replacement?
I am in the middle of a restoration. There is no interior.
Old Aug 3, 2004 | 05:20 PM
Jim Shea's Avatar
Jim Shea
There are no other complete GM steering columns that will interchange into your 1975.
Vette T&T columns from 1969 through 1976 will bolt right into your 75.
Parts from Cadillac and Oldsmobile T&T columns from the 1969 - 78 era (i.e. round head without the dimmer bulge on the left side) can supply parts for the head portion of your steering column. The tubular part of your steering column (i.e. jacket, shift tube, and steering shaft) are all unique to the Corvette.
Old Aug 3, 2004 | 08:03 PM
scotty13's Avatar
scotty13
In particular i was looking for the two halves of the tilt section ( the piece joined with two big pins on the sides)
Are these also in the caddy and Olds columns?
Old Aug 3, 2004 | 08:56 PM
Jim Shea's Avatar
Jim Shea
The lower part, called the support, is bolted to the tubular part of the steering column and is nearest the instrument cluster. It is the same for all tilt and T&T columns from 1969 through 1982.
The upper part (that actually tilts) is unique to T&T columns and should be the same for T&T columns of that era.
I might suggest that you download this steering column blowup picture. It will help to identify the pieces. For instance, the lower part is #49 Bearing Housing Support. The tilting part is #24 Bearing Housing.
http://www.corvettefaq.com/c3/T&TCol...cRev03FE04.doc
Also the following paper describes a number of steering column parts that are interchangeable between T&T columns and Tilts.
http://www.corvettefaq.com/c3/ColumnPartsR&R25FE04.doc
There are many more papers on steering that are also available at the www.corvettefaq.com websight in the Steering section.
Good luck,
Jim Shea
To Tilt-Tele column question
