7/16 Studs?
Old Aug 5, 2004 | 01:53 PM
jeromeunderwood's Avatar
jeromeunderwood
Default 7/16 Studs?
82 Cross fire, What size studs in valve train?
Old Aug 5, 2004 | 02:15 PM
gerry72's Avatar
gerry72
The bolt shank that screws into the head is 7/16 but the stud shank (what the rocker goes over) is 3/8. You can upgrade to 7/16 stud but that, of course, requires changing to 7/16 rockers too.
Old Aug 5, 2004 | 02:18 PM
jeromeunderwood
Thank you... I'm ordering 1.6:1 roller rockers and may gho with the 7/16 and change out the studs.
Old Aug 5, 2004 | 02:25 PM
Fevre's Avatar
Fevre
Stock press in studs are 3/8th for sbc, you can get screw in studs in both 3/8 and 7/16.
Old Aug 5, 2004 | 03:01 PM
Gordonm's Avatar
Gordonm
You don't need to go to 7/16 studs unless you are running big spring pressure. Like 400 pound springs or higher. That is solid roller territory. The 3/8 screw in studs will work fine in most SB applications. The 7/16 studs are BB studs put into SB heads.
Old Aug 5, 2004 | 10:33 PM
LiveandLetDrive's Avatar
LiveandLetDrive
With 3/8 studs e.g. ARP Pro Series (190 or 200k psi) surely a hollow pushrod would fail long before the stud.
-Chris
To 7/16 Studs?
