Transmission disaster (auto)
Here's the rest of the story: While reinstalling the valvebody, the S-link to the shifter linkage fell, naturally there was a hole straight below it, into the mysterious, frightening interior of the transmission. Endless strings of the familiar 4-letter-words (and a few new ones I invented for the occassion) didn't bring it back out, nor did flipping the trans on the engine stand and shaking it. ...or so I thought... I give up now and move it to the workbench, remove the pump (no slidehammer required) and start removing parts. I couldn't find it, but of course, it turned up on the floor where it had been on the stand
Everything goes back in, using an old transmission rebuild book as a guide. I didn't replace any internal seals, nor the pump gasket although I used some gasket-making goo on that.At this point I just plan to completely strip the thing and buy the $90 complete rebuild kit. I don't want to risk more downtime (this is my daily driver, currently bumming a ride) It does have 82k miles on it and that was probably the first time the pump had been off since the factory, it probably needed it anyway.
Sorry for the novel, please give me some ideas of what may have gone wrong in my reassembly. Could the pump be oriented wrong, or just leaking? Some else internal screw up?
Thanks for the help,
Chris
Anyone else had this experience or have any ideas as to the cause?
Any other modifications while I'm in here (cheap)
-Chris
Hopefully someone more up on these units will chime in. Good luck.
steve
had that happen....If you put it in low and shift manually it should shift into 2 and 3 and you can normally limp home when this happens...
-Chris
Found a strange foreign object in there that may have been part of the havoc... see: http://forums.corvetteforum.com/showthread.php?t=883671
-Chris
