$@%#% rear shock mounts
: I give up. I'm cutting them out. That is all
I think they're junk anyway since when I pulled the shock off the surface wasn't even round and smooth. I'll try to take some pictures tonight.
I'm not sure if mine are as bad as others due to the fact that everything else has come apart with ease; even the trainling arm bolts came out with only a slight tap of the hammer.
When reassembling, use copious quantity of Never Sieze paste for future removal ease!
All in all, not as bad as other chores on these puppies.
"There is no such thing as too big a hammer"
NJ BB Ken
.....go figure.
i thought the knurl near the shoulder is what locks the thing in??
rod bushing has fused (with rust) to the shock mount.
I ended up cutting through my strut rod end and grinding away
at the inner sleeve to get mine out. I replaced with adjustable
strut rods from VBP. Well, truth be told - it was for nothing.
Mine were also rusted in the shock mount area like
yours. They are too loose to use now. The end of the shock will
flop around on that. Buy new (or good used) ones.
For getting the old ones out, try a 2 or 3 jaw puller - but grab the far side
of the bearing support to pull against, or you will end up breaking
off the bearing support ear.
