Great looking pic. I recommend NOT using the stock sensor or wire. If you do, then you're going to have problems. The stock sensor and temp guage are calibrated with each other...the sensor makes more resistance the higher the heat of the engine. Adding another device to the sensor will screw up the amount of resistance the temp guage is measuring. Would be much wiser to just use another water port.
It looks like you bought the rad and fan combo from Tom DeWitt right? It should have come with its own sensor. That sensor will allow the fans to turn on and off at the correct temperatures. If you don't want to install it in the thermostat housing you should have another open port in one of the heads. I installed mine in the thermostat housing and have had no problems.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Yes, but I wanted to reduce some of the engine compartment wiring.
Len, Marshrat99 is on the right track. The stock temp sensor is an analog variable resistor changing resistance with temperature. The Temp sensor supplied with the Spal fans is a discrete switch set to close the circuit to ground at ~170 degrees (not sure about the temp....depends on which temp sensor part you have) Using the stock sensor won't work. If you connect both fans to a single temp sensor, be carefull... the current surge of turning on both fans at exactly the same time took out the voltage regulator in my alternator.... even though I supposedly upgraded the alternator to handle 100amp. I replaced the voltage regulator and wired the secound fan to operate manually. So far I have'nt needed the secound fan, but the summer has been pretty mild here. I choose to hook my 12volt power source for the fans down at the starter B+battery terminal. I haven't had time to troubleshoot ....but if I have too much resistance in my alternator charging wire and/or my battery terminal, that might explain a reverse voltage spike that takes out the alternator regulator when running both fans???? Best to stagger the fan turn on.
"Rodstoration &am p;quot; In Progres
I recently finished my dual spal installation... just spliced the two black wires (one from each relay) together and attached to the temp sensor on the intake manifold. Kept it clean and works well... all it does is ground out the relay. I also installed a ground override switch in the car so that I can manually activate the fans if wanted/needed.
