engine stumbles when I floor it
Old Aug 13, 2004 | 01:25 PM
Lohkay's Avatar
Lohkay
Default engine stumbles when I floor it
Hey guys.. I rebuilt the engine in my frame-off and the only change was a switch from the q-jet carb to a holley DP 650. I didn't change anything on the carb but if I open the throttle real fast the engine bogs for a fraction of a sec and starts reving. If I take a bit more time to open the throttle (still fast but not instant) , it'll rev just fine. I'm guessing my idle is spurting too much fuel.. is this right?
Old Aug 13, 2004 | 01:35 PM
Shark Racer's Avatar
Shark Racer
I'm thinking this might have something to do with the accelerator pump giving you too much of a shot...
-Steve
Old Aug 13, 2004 | 02:43 PM
The Dude's Avatar
The Dude
-Steve
Or too little.
Or the squirter(s) are too small. Or too large.
Or the float level is too low. Or too high.
Old Aug 13, 2004 | 04:04 PM
Nick-75Roadster's Avatar
Nick-75Roadster
Accelerator pump discharge nozzles sound like they are too small. The shooter is fairly easy to change (shouldn't even need to pull the carb). I would purchase a slightly larger one or purchase small diameter wire gage drill bits and a pin vice and gradually increase the size until the stumble goes away.
Old Aug 13, 2004 | 08:21 PM
stingr69's Avatar
stingr69
Check the accelerator pump linkage for slack. If there is any slack this will cause a hesitation you describe.
-Mark.
Old Aug 13, 2004 | 09:02 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
-Mark.
Assuming that the problem is due to the carb change, I'd suspect a sudden lean condition caused by not enough fuel to match the increases airflow. You didn't say under what conditions this is occuring. If it's while your blipping the trottle at idle, it's very likely an accellerator pump delay. If you're mashing the throttle in gear at low rpm, it could be just the nature of a mechanical secondary carb having the secondaries opened too soon.
Old Aug 14, 2004 | 02:04 AM
BatManFire's Avatar
BatManFire
I'm having somewhat the same problem with my 650 dbl pumper. I just rebuilt it which helped tons but there is still a super slight stumble in mine on a quick mash to the floor. I'm going to check the accelerator pump to see if there is any slack there.
Old Sep 13, 2004 | 01:54 AM
Lohkay's Avatar
Lohkay
To end this thread, the solution was a bigger cam for the accelerator pump. Went fairly large actually so a increase in nozzle might be worth it.
Old Sep 13, 2004 | 09:13 AM
76REDSTINGER's Avatar
76REDSTINGER
double pumpers have 2 shots.....bog is usually too much fuel
To engine stumbles when I floor it
