Compression fittings Safe ?
Old Aug 16, 2004 | 04:03 PM
rustbucket80's Avatar
rustbucket80
Default Compression fittings Safe ?
Will compression fittings on the brake lines pass inspection ? Are they safe? I found where it looks like someone spliced a piece of brake line going to my back brakes. It looks like it's been there a while. Should I just leave it alone?
Old Aug 16, 2004 | 04:36 PM
markdtn's Avatar
markdtn
NO! do not use compression fittings in a brake line. I would get a new line immediately or find a double-flare union to replace it with. You might have enough tube left to flare it and join them back together. Good stores have them (NAPA, CarQuest, etc.)
Old Aug 16, 2004 | 04:37 PM
Stewart's74's Avatar
Stewart's74
Get a new front to rear brake line.
Old Aug 16, 2004 | 04:38 PM
CGGorman's Avatar
CGGorman
NO!! Flare at least. It may not be a compession fitting, though. Can you get a picture of it?
Old Aug 16, 2004 | 07:09 PM
DollaGreen's Avatar
DollaGreen
Old Aug 16, 2004 | 07:55 PM
rustbucket80
I went out and took it apart. It has the little sleeves or rings. I am sure its a compression fitting now.
Old Aug 16, 2004 | 10:03 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
If it's a hydraulic compression union it would have a double compression sleeve on each end, and would probably be made of steel, not brass. Those would probably work, but a new line is certainly in order. I would do a new line before doing anything like that.
To Compression fittings Safe ?
