Bouncing Speedometer Needle
Old Aug 17, 2004 | 12:39 PM
Texaggie's Avatar
Texaggie
Default Bouncing Speedometer Needle
The speedometer needle in our 72 bounces all over the place as we are driving. Its a new cable and it appears to be connected securely.
I would appreciate any suggestions as to how to tame it.
Old Aug 17, 2004 | 01:19 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Greasing the speed cable would help unless the cable is broken. Most major vette parts suppliers sell an adapter that screws into the cable and allows a grease gun to be attached on the other end.
Old Aug 17, 2004 | 01:23 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
It would be a good idea to grease it somehow.
Old Aug 17, 2004 | 01:47 PM
Crash80's Avatar
Crash80
When my upper speedo cable got a bad case of the bounces along with being noisy, I took it out and slathered it with white lithium grease. I figure I am good for another 20 years before I have to do it again.
Old Aug 17, 2004 | 04:35 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
If you have installed a new cable and it is still bouncing, You speedometer head could be binding up.
Old Aug 17, 2004 | 05:12 PM
JOliver's Avatar
JOliver
Grease the cable first ,if that doesn't fix it check the cable routing out to see if there are any binds in it anywhere.If those two don't work the speedo head might be worn out.It happens
Jason
VetteInstruments@aol.com
Old Aug 17, 2004 | 09:37 PM
norvalwilhelm's Avatar
norvalwilhelm
YOu need to reach under the dash and remove the speedometer cable from the back of the speedometer. Pull the end out from under the dash, slide the inner cable out and grease it with either speedometer grease of white grease and slide it back in.
Unclipping from the rear of speedometer is tricky but it is a tap that you have to push at the same time as you pull the outer speedo sheath back for the rear of the speedometer
Old Aug 18, 2004 | 02:30 PM
BIGBYRD1993's Avatar
BIGBYRD1993
Cruise-In XI, XII Veteran
NCM Lifetime Member & Ambassador
You might want to replace the Transducer, if you have Cruise Control.
Had the same problem when I got my ' 77 and it cured the problem.
To Bouncing Speedometer Needle
