Removing sap from paint
Old Aug 19, 2004 | 10:48 AM
Ken74Conv's Avatar
Ken74Conv
Default Removing sap from paint
What is the best way to remove sap from the paint without harming the finish?
Old Aug 19, 2004 | 10:51 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Ummm...wash your car with soap and water???
Dep
Old Aug 19, 2004 | 10:58 AM
mayberg's Avatar
mayberg
I have good luck getting crap off with WD-40.
Old Aug 19, 2004 | 11:00 AM
PRESSURERAT's Avatar
PRESSURERAT
Dep
Old Aug 19, 2004 | 11:03 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Dried sun baked sap can be as difficult to remove as paint spatter. Try one of the clay bar systems on the market, they work wonders for removing contaminants from paint...
Old Aug 19, 2004 | 11:07 AM
72GACRZR's Avatar
72GACRZR
Old Aug 19, 2004 | 11:09 AM
DJ Dep's Avatar
DJ Dep
Why would you park ANY car under a tree??? Between bird poop and sap, you are ASKING for a mess to clean up.
And I agree with WD40.
Dep
Old Aug 19, 2004 | 11:17 AM
page62's Avatar
page62
What? Spray the entire car with WD-40?
Try using glaze remover. It has several names, like "Kleeno".You can get it from a auto paint supply shop. But you'll have to wax the car afterward. (But that'll make it easier to wash off the sap next time...)
Oh...and try it on an inconspicuous place first!
Old Aug 19, 2004 | 11:34 AM
mrcorvette79's Avatar
mrcorvette79
WD-40 is not a good thing to use on paint. Remember it's a penitrating oil and ALL paint surfaces are poris wheather it's Baseclear or Lacquer. The end result will be if you ever need to paint that surface in the future you have a mess of fish eye craters, or at the very least a pale yellow streak may show up on lighter color paints .Tree sap is oraganic and removal should be the same, soap and water first followed by a paint cleaner like Zymol cleaner. Tar Bug is decent in small areas as well as mineral spirits. End the process with a good washing again and a coat of polish.
Old Aug 19, 2004 | 11:46 AM
Brettmc's Avatar
Brettmc
My brother the body man told me that the dried chunk of sap on my Burb was there to stay. However, I took most of it off with a razor blade.
Brett
Old Aug 19, 2004 | 12:15 PM
Dick72LT1's Avatar
Dick72LT1
I've had good luck with commercial tar and bug remover. It's safe on paint. In my experience, it takes patience. Keep the spot wet for a while and rub the loose stuff off occasionally. It probably won't come off in one swell foop. If you end up with a "ring" where the edges dried harder than the center, try polishing compound or a "cleaner wax".
Old Aug 19, 2004 | 12:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by yellow 72
...Try one of the clay bar systems on the market, they work wonders for removing contaminants from paint...
Old Aug 19, 2004 | 01:12 PM
DJ Dep's Avatar
DJ Dep
An alternative to WD40 is Ballistol. It can actually be put in your car wash bucket along with soap. We AREN'T talking about spraying the entire car in WD-40 BTW. It's for indivudual sap areas. If I wanted the whole car coated I'd dip it instead.
Also, WD40 is actually not a "penetrating oil" like Liquid Wrench or PB Blaster. It's much more lubricant than penetrant. If you wanted to paint an area that was shot with WD40 or any other lubricant/oil, the correct way is to PREP it first. Unless your name is Bubba
Dep
Old Aug 19, 2004 | 03:41 PM
mrcorvette79
Dep
I believe using WD-40 on your paint would qualify for membership in the Bubba club I would like to hear the explanation given at a forum members repair shop when they explain how someone told them to use a "Lubricant" on their paint to remove sap. I've worked too long in the automotive industry at the manufacturing level to hear all of the great and informative suggestions most of which were good ideas when dirt was new !. Don't take me wrong, opinions are like ***' everybody has one, but don't send out information that could damage someones classic.
DJ Dep, no need to cop an attitude about my reply, your post has some good content and useful information.
Old Aug 19, 2004 | 03:42 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Claybar
Old Aug 19, 2004 | 04:42 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Another vote for claybar. The process is amazing, it will even remove overspray.
Old Aug 19, 2004 | 04:57 PM
DJ Dep's Avatar
DJ Dep
Cripes! Are you changing your paint color as often as you change your oil???
I have used WD40 for MANY years to take crap off my car, including tree sap and road tar. Spray it on. wipe off the junk, and use a cleaner/wax if you are all that worried. Road oil gets all over a car when it's driven on the street so any COMPETENT paint shop better take that into consideration BEFORE they start spraying.
No attitude...but lets apply the answers to real world situations.
Unless people are racing their Vettes at NASCAR events, body damage and repaint should be a pretty rare event.
Dep
To Removing sap from paint
Old Aug 19, 2004 | 04:58 PM
Blue Ace's Avatar
Blue Ace
One more vote claybar.
Old Aug 19, 2004 | 05:58 PM
73Ken73's Avatar
73Ken73
Carb cleaner works good. I follow it with windex and then cleaner wax
Old Aug 19, 2004 | 06:07 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Not to get off topic here, but if you
wipe the entire car down with WD-40
after a good wash, it will not create a
static cling for dust.
