Starting Eng on Chassis
Old Aug 24, 2004 | 07:31 PM
Simul8's Avatar
Simul8
Default Starting Eng on Chassis
I'm looking to fire the eng up on the chassis before I drop the body back down. What do I need connected to the Alternator? I have the original style installed. Can I just run a wire back to the battery or do I need to connect the 2 wire connector up some how?
Also any thing else I should know or be aware of?
Old Aug 24, 2004 | 07:44 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
You don't really need to hook up the alternator to fire up the motor. I broke in my motor before I dropped the body, and I didn't hook it up. All I did was hook up temp and oil pressure gauges to moniter those functions.
Old Aug 24, 2004 | 08:50 PM
Simul8's Avatar
Simul8
So I can just run off the battery? I thought I could, but just wanted to check. Thanks!
Old Aug 24, 2004 | 09:13 PM
7t2vette's Avatar
7t2vette
No problem!
Old Aug 24, 2004 | 10:11 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Be sure to remove the radiator support before you drop the body back on. I learned the hard way, but it was a good idea to start her up to make sure there were no problems. I just used jumper cables and a start switch I rigged up, worked just fine.
Edit: The radiator support can not be attached to the frame during the body drop as it will not allow the body to clear. If the support is attached to the body during the drop it will add extra strength and stability to the nose of the car. I hope I didn't confuse too many of you with my first reply?
Old Aug 25, 2004 | 12:10 AM
NHvette's Avatar
NHvette
Yup - just add power to ignition and starter.
I don't even have the gas tank yet - just stick a couple hoses into the gas can.
I rest the radiator on some foam pads over the frame horns.
My hoses do a good job of holding it in place.
Make sure you are not in gear. You don't want the chassis taking
off on ya.
Old Aug 25, 2004 | 06:46 AM
Big Fish's Avatar
Big Fish
Originally Posted by NHvette
Make sure you are not in gear. You don't want the chassis taking off on ya.
I remember that I was really worried about this as well. I sandwiched the frame between my service truck and Suburban just to be safe.
Old Aug 25, 2004 | 07:05 AM
comp's Avatar
comp
post some pic's of your work
Old Aug 25, 2004 | 12:26 PM
Simul8's Avatar
Simul8
Here's a couple of pic's.
To Starting Eng on Chassis
