Back to roll cages again
(weird norval how you have opposing views on the 2, a chrome moly cage where in all reality it doesn't serve any real purpose over the mild steel one, yet no better calipers LOL
) Seamless cold drawn mild steel will get the job done and won't cost an arm and a leg or be a total PITA to weld (you could gas weld the 4340, I assume you have a gas welding kit?)As for chrome moly being stronger than mild steel, yes it is but is it also tougher? No. Tensile strength is just the max. tension a material can take before it snaps, the yield strength is where the material keeps deforming without any increase in load on it. This is plastic deformation, beyond the elastic region. Permanent deformation is the result. Before the steel snaps when you pull it apart it forms a neck where the material has gotten thinner. The amount of reduction of area is a measure for toughness, the greater the difference (just before snapping) the tougher the material. There's also elongation, the amount of stretch before it snaps.
here's the numbers for mild steel and 4340:
4340:
elongation 28%
reduction of area: 52%
mild steel:
elongation 38%
reduction of area: 62%
So, mild steel is tougher than chrome moly. This is important in a cage, the fact that the material has more "give" in it means that it will absorb more impactand thus dissipating energy.
Apart from that it's hard, so difficult to cut, saw, drill - if you drill it and the drill goes blunt you have to temper the material because it will get brittle from the friction heat > out comes the ox/ac torch again - it needs tempering after bending, cutting, welding...anything that
I don't see why you would want a chrome moly cage.
Here is an example from www.ioportracing.com
I agree with the comments advocating the use of DOM - mild steel versus chrome moly. TT hinted at the heat affect zone (HAZ) issues you will have with the welds. With a "tempered" or heat treated/ hardened metal the HAZ will be weakened back to its annealed state. The cage is only going to be as strong as the welds and HAZ areas. So you may want to look at the properties of the alloy you are considering in its annealed state (to determine whether you'll need to heat-treat it back to a stronger state) as well as the properties of the weld material. You will want to pay attention to yeild strength as well as tensile strength for the reasons cited. I have not done the math yet as to strength/ material needed to reduce flex and protect on impact/rollover. I'm hoping that 1 5/8" DOM will do the trick. Hopefully I'll be able to report back in a couple of months with those results.
Regarding the location of the frame tie-in points, I've been assessing my/our frame(s) for weakness/flex - both from a reaction to engine torque and a handling perspective. It would be a waste to put in a cage that only improved on protectiveness. The two major weakpoints are 1) at the kick up point behind the seat and 2) near the footwell where the frame narrows to accomodate the front suspension. Providing "triangulation" is the most efficient way (least material/weight) of providing strength. For the kickup I've been thinking that tieing the "rollbar" into the kickup 5-6 inches up and then running at least 2 bars off of the rollbar. 1 bar would connect back near the number 4 body mount, and the other bar forward to the footwell area.
Like Norval, I don't want to cut up the interior or give up the ability to take the body off the frame. I want the car to still be a comfortable daily driver (when desired) and as well safe for "competition". I've been trying to figure out a way to connect the cage to the frame in a manner that provides the required strength, but can be unbolted/slid out (that would easier with a convertible than a coupe). I am considering a two-piece cage similar the IOport illustration where the front could be removed for daily driving use.
Regarding the frame tie in near the footwell I was thinking that it might be best to weld a section of rectangular "boxed" material to the end of the tube below the floor and then either weld or cross bolt the boxed material to the side of the frame.
I'm up early to go to Carlisle - so no busts regarding post time/day please. Gotta hit the road!!
We have a state of the art knotcher at work. It is a $12,000 knotcher that uses a large milling cutter and you just dial in the angle and the diameter of pipe and it does a perfect job.
We have 3 race teams in the university, one in a Indy car, one off road team and one solar team. Each year they build a new car from scratch and each has a budget of over $100,000. I see a truckload of slicks come in yearly, just not my size.
I will go with mild steel. You convinced me.
I was reading the GM chassie book last night and they have drawings and dimensions on the cage for a crovette and they used 1 1/2 tubing .095 wall????
D.O.M. STands for drawn over mandrel. Found it last night on the internet.
Thanks Big632
In ANYTHING on our cars were are looking for elastic limits, not yield points. Yield points are too late. Elastic limits are what is used in design. An elastic limit is the point at which if we go beyond we plastically deform the part and it never returns to normal.
Every time we torque a bolt we are reaching towards the elastic limit but not exceeding it. Go beyond it into the plastic zone and the bolt is ruined.
The 6 calipers?? I was just convinced they are needed. I am not convinced Chrome moly is needed anymore so I am going mild steel. I will use the standoffs like in another of your posts suggested.
I will tear the interior out completely and start over so that is the time to do a complete job. The winter is long.
I am definitely goind with standoffs. They will be welded to the frame and pass through the floor where the main cage will be welded on. In my mind the have them pictured and I can make they look really nice and all welding of the cage will be in good locations for complete welds and at the same time I will keep it neat. I will fiberglass them in and reinsulate the floor.
I work in a welding research center/part of the university and we have the knowledge to do good welds, well at least on paper we have the knowledge. I also have a friend but I will not call on him but he is availabe that has build at least 10 complete chrome moly indy chassies complete with many many tubualar A arms as spares in case of accident. He would do any tig welding I want.
But being me I will do all my own welding and since I agree on mild steel I know I can do picture quality welds.
Tie in points in the back will be as far back as possible and still get a good spot on the frame and in the front as close to the a arms as possible.
I also need to add a spreader bar at the same time.
I will not bolt to the frame, bolts always have a little give. I will weld everything and hope the frame never needs changing.
Take 4340? The first number 4 means moly. Moly prevents brittleness . Any steel beginning with 4 or 8 means moly a good thing.
The 3 stands for chrome and nickle so from that number we know it is an alloy steel containing these 2 elements.
The last to number, 40 refers to carbon content. In this case it is .4%.
So anyone knowing how to read the numbers just looks at any steel and can tell you the makeup and what those elements added to steel does.
When designing anything we always worry about yield points, not ultimate tensile strength, not percent elongation. These are all too late, In a bridge it is great, it is the last line of defence before the bridge falls down. Sure it is sagging due to plastic deformation but again the bridge is doomed.
Yield point is an elastic band, stretch it over and over , millions of cycles and it always returns to normal, elastic range, Just exceed the elastic limit just ONCE and it plastically deforms and never can be put back to normal. Every bolt has a torque value, it is below the elastic limit but close to it for maximum clamping force.
We calculate/test for yield point, ultimate tensile stength, % elongation but want to stay away from them all. Reach either of them and the part has failed. The yield point ALWAYS come first and that is the one to stay away from, you can get close but never exceed it.
I know this is getting off topic but it might be of interest to some of you.
Both of us gain a little from the borrowing. Their knowledge is free like on this forum.
I do think I have it under control now that you guys have set me straight.
Thank you.
It is copied from their site
The most frequently asked questions regarding roll bars and cages have to do with the different types of materials used in their fabrication. Generally, there are three different materials used: ERW, DOM and Chrome-moly. ERW stands for Electric Resistance Welded and this is a mild steel that is made from a flat sheet, rolled up into a tube and welded. DOM stands for Drawn Over Mandrel. This tubing is actually ERW tubing that has gone through an extra step to even out the imperfections and make it stronger. Chrome-moly is an alloy of steel which incorporates both Chromium and Molybdenum in the process and is stronger still. NASA’s rule book is very clear about what tubing is required for different weight cars and different classes. The rule book will tell you what is allowed and narrow down the choices.
Norval, am i understanding that youa re getting new calipers?? I'd get some GT mount patter ones (5,25" spacing) since all the big calipers seem to have that (some have the 3,5" spacing) and this means that you can run a lot of different calipers.
I may have to get a tubing notcher, they don't sell those things here but I will have to have one shipped then..why they don't sell it here is beyond me (well, they have a 2000$ one but i'm not gonna spend that, just looking for a nice one w/ an angle plate that uses hole saws), I do all the notching by hand now by making patterns with a protractor and laying it over the pipe. A lot of work but it gets the job done...slowly.
Not a chance twin turbo. I still think my stock calipers are more then adaquate.
Our work notcher is overkill. It was $12,000 and you just dial the pipe diameter and the angle you want and a large milling cutter cuts the proper angle. Since it is available I will use it but with a hand grinder and a little patience you can do almost as good. I wouldn't spend too much on one. I can also borrow the hole saw type if I want.
I was using some plastic pipe and laying the various bars out, it still bothers me cutting up the car and putting bars in the interior.
My sons company buys large quantities of it and I can have any amount I want cheap. The goes also for mild steel tubing. He has dies for 1 1/2 and 1 3/4 but no 1 5/8's. ON monday he is going to give me samples of his tightest radiuses on both these dies. Dies come in large and small radius.
In the past I used stainless, 1 5/8's schedule 40 which means 1/8th wall. That cost $1.05 per foot if I went that route.
What do you guys think about stainless?? The mustang is stainless, sure polishes up nice.
We have a specialty stainless tubing shop a few miles away that specializes in bending/welding/selling this tubing cheap.
