C3 conversion: transmission (6SPD) and engine (LT1)
Old Aug 31, 2004 | 05:25 PM
24Hours's Avatar
24Hours
Default C3 conversion: transmission (6SPD) and engine (LT1)
I am looking for information regarding a conversion I plan to start on my 1981 Vette. I have been told that a 1995 Vette 6SPD tranny (ZF) will not fit in the transmission tunnel of a 1981 Vette without major modifications. I also understand that a 1995 Vette LT1 would be an easy fit for this 1981 car as well. I currently have a 1995 Vette (53K miles) with engine and transmission for parts. Additionally, it has been suggested that the Camaro T56 transmission is best suited for my application because of size and durability. I am also contemplating putting a 1997 Camaro LT1 engine in this 1981 car since I have access to a 1997 Camaro LT1 and T56 with low mileage. Any information you have regarding this conversion would be extremely helpful to me. If you have any other insight for me on this conversion, please feel free to share your thoughts.
Thanks in advance for your help.
Old Aug 31, 2004 | 07:09 PM
Twin_Turbo's Avatar
Twin_Turbo
The ZF will fit if you widen the tunnel but the T56 is a much easier fit. The ZF has the added problem of only being available with the torque arm mount so you have to build your own transmission mount. I have modified all these things to fit the ZF in my car and it fits but it's real snug and I may actually cut away the transmission tunnel and weld in a custom one to give the tranny more room.
Old Aug 31, 2004 | 07:19 PM
24Hours's Avatar
24Hours
What engine did you bolt the tranny too? If you had to do it over again, would you put in a T56?
Old Aug 31, 2004 | 07:23 PM
PatsLs1vette's Avatar
PatsLs1vette
The lt-1 should be no problem either plenty of guys have done it here and a few have done tpi,like me.
Old Aug 31, 2004 | 07:35 PM
Twin_Turbo's Avatar
Twin_Turbo
Just the normal small block but there's no rel difference there, dimensions are about the same. I kind of had no choice, there are few T56s here and this ZF was about the only one I could get my hands on, fabricating the necessary parts isn't that hard and I don't mind chopping up my car, the entire thing is far away from stock anyway.
Here's my trans mount:
As you till probably notice, the crossmember is a custom job also, the entire center section is built from scratch. I also modified the bracket that holds the shifter (the thing with the round hole) so to give more room, I'm using a TH400 yoke and otherwise it wouldn't slide in far enough so I did that to give more clearance.
This is how close the fit is, near the firewall it isn't a problem but at the rear it is. I had to cut open the floor quite a bit for the shifter to go through and the tranny mounting bracket I made actually pokes through the hole, it's higher than the floor used to be in that area.
Old Sep 1, 2004 | 05:35 AM
24Hours's Avatar
24Hours
How did that effect the interior of your car when you modified the tunnel?
Old Sep 1, 2004 | 07:18 AM
75rag4sp's Avatar
75rag4sp
Default No Cut overdrive option
24 Keisler Engineering has a bolt on No Cut system for the C3 that will yeild you a .64 overdrive. I cosidered a 6 speed but really fond no need for the second .50 overdrive. The TKO will handle upto 650hp and requires no change to yor car.
Old Sep 1, 2004 | 08:25 AM
flaskier99's Avatar
flaskier99
Take a look at this. This is something I have been thinking about for awhile. My turbo350 is about to need a major rebuild so I may do this instead. Seems pretty straight forward, a step by step guide for the T56
http://www.vetteweb.com/tech/0407vet_6speed/
Old Sep 1, 2004 | 09:09 AM
24Hours's Avatar
24Hours
Great information. Thanks!
Old Sep 1, 2004 | 12:32 PM
Twin_Turbo's Avatar
Twin_Turbo
Not that much, the tunnel is just a bit wider, the original seats should still fit, not that I'm going to use them but it should still fit. Leg room is the same, as the only area I widened is aft of where the original shifter cable went through.
To C3 conversion: transmission (6SPD) and engine (LT1)
