Sheet metal welding.
Old Sep 1, 2004 | 03:42 PM
Corvus's Avatar
Corvus
Default Sheet metal welding.
For those of you who took off your carpets, and welded sheet metal to your floors could you post some pics please, and how much did it cost ya?
I don't have much rust when I took my carpet off but I think I'm gonna do it to make floor strong.
Old Sep 1, 2004 | 06:57 PM
comp's Avatar
comp
iv'e seen some that were bonded in
Old Sep 1, 2004 | 07:50 PM
Corvus's Avatar
Corvus
No one has pics or info :-P?
Old Sep 6, 2004 | 02:33 PM
Red_Shift's Avatar
Red_Shift
Mine were weleded into my floorboards when I purchased my Corvette. I never new why they were there. Is this a common rust problem on Stingrays? I'd show you pictures but I'm still in Kuwait. I'll take photos for you when I get home if you can wait that long.
Old Sep 6, 2004 | 03:18 PM
DaveL82's Avatar
DaveL82
I have an 80 which also has the metal floor pan. from 75 on up all vettes had them to work with the increased heat of the catalytic converter. Before that they were just fiberglass!
My 80 leaked when it rained and I had rust but turned out it was just on the surface so I didn't need to add any additional metal. Do you have rust through on yours?
I agree that even with the stock floor the metal is very thin. You could cut some 4 inch square 1/16 inch steel and bolt it in at the corners with 3/16 or 1/4 inch bolts so that where the seat bolts it has move surface area. The plates would have to be on the bottom to stop the seat from pulling out of the floor pan. My 80 does have a channel at the front bolts underneath but this is flimsy also.
Old Sep 6, 2004 | 08:20 PM
Lotus76's Avatar
Lotus76
You may want to consider Por 15 products. Power mesh reinforcing Fabric does a great job with por 15 .
Check it out...
To Sheet metal welding.
