Had alignment done.
Old Sep 2, 2004 | 07:58 PM
Blue Ace's Avatar
Blue Ace
Default Had alignment done.
I installed a new trailing arm on left side and sent car to have it aligned.
I noticed that I could move the shims up and down a little. Is this O.K.?
They are snug but I still can move them.
Old Sep 2, 2004 | 09:57 PM
zwede's Avatar
zwede
Tighten the nut a little more. It's probably ok, but I'd feel better if it was tight enough so I couldn't move the shims. Also be sure you install the shim locking pin so they can't fall out.
