Flywheel ???
Old Sep 11, 2004 | 07:44 AM
Fleetwood's Avatar
Fleetwood
Default Flywheel ???
Those of you who have changed from auto to manual transmission,what size flywheel did you get?
My current flexplate has 168 teeth on it,can you get a flywheel with the same amount of teeth,to save changing the starter motor?
Thanks Neil.
Old Sep 11, 2004 | 09:14 AM
Gordonm's Avatar
Gordonm
Yes get the 11 inch clutch and flywheel. That flywheel also has 168 teeth. That is the bigger of the two flywheels. I think the smaller is a 153 tooth. You would not have to change the whole starter just the nose of the starter is changed to go with the smaller flywheel.
Old Sep 11, 2004 | 09:25 AM
comp's Avatar
comp
i think so also
Old Sep 11, 2004 | 09:29 AM
CGGorman's Avatar
CGGorman
Interesting.
Flexplate = Automatic?
Flywheel = Manual?
Old Sep 12, 2004 | 05:23 AM
Fleetwood's Avatar
Fleetwood
Thanks for that,but I think I have tha smaller bellhousing,so will look for a 10 1/2" flywheel as you say it only means changing the throwout gear.
Neil.
Old Sep 12, 2004 | 10:14 PM
Fleetwood's Avatar
Fleetwood
Does the flywheel need to be the same diameter as the flexplate to pick up the starter motor gear?
Thanks Neil.
To Flywheel ???
