14 deg plus? for wot?
Old Sep 19, 2004 | 01:05 AM
76REDSTINGER's Avatar
76REDSTINGER
Default 14 deg plus? for wot?
what is the stock mechanical full timing advance on a 76 HEI dist?
just put in my new comp cam XE 268 cam!!!!!!
hope it holds up.......its the one for the power band i want.
seems to like 14 deg initial advance.
R.
Old Sep 19, 2004 | 08:14 AM
62fuelie's Avatar
62fuelie
Don't be too concerned about the initial number. It is probably a combination of initial and some centrifugal anyway, unless you have the idle speed turned way down. What you want to check is to see that the TOTAL advance with vacuum disconnected runs in the 36-38* range. All the mechanical advance should be in by 3000 RPM. At cruise settings, the vacuum advance should kick in another 16 deg +/-.
Old Sep 19, 2004 | 09:26 AM
comp's Avatar
comp
3000 seem's to high
Old Sep 19, 2004 | 10:53 AM
76REDSTINGER
im running an auto trans w/ 2500 stall
ive been told that you subtract stall speed from max power band rpm
5800-2500 = 3300
divide by 2
3300/2 = 1650
add to stall speed
2500+1650 = 4150rpm
this is where you want the full advance to come in.
any one else agree?
Old Sep 19, 2004 | 12:29 PM
lars's Avatar
lars
You want to set up your distributor so you get 36 degrees total advance at 2500 rpm max. Tailor your curve so you can get about 16-18 degrees initial advance while maintaining the 36 total. Use a vacuum advance control unit that pulls in an additional 16 degrees.
Old Sep 19, 2004 | 01:41 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Can't go wrong with LARS advice. Mine has 17 degrees initial, 36 @ 2500RPM and 52 total, runs like a raped ape.
Old Sep 19, 2004 | 03:54 PM
76REDSTINGER
thanks lars.
i just changed from an isky 2800-6500 oval track cam-(not my doing)
to the XE268 went for ride today getting hesitation below 2200 rpm
i did not before
before the cam swap i put on
edelbrock eps performer intake
edelbrock 600 performer carb
set HEI timing curve w/ spring kit (used lightest springs)
ran good but power was way on top.......
now seems to be lean surging.....w/ hesitation below 2200rpm
reset timing to 14 deg
reset idle mix drawing approx 13 in/mg at idle
i have a new 750 performer carb .......600 too small for new cam?
Old Sep 19, 2004 | 03:57 PM
62fuelie's Avatar
62fuelie
With an auto trans 2500 would be better. 3K would be an absolute max. On both my Vettes, (one conventional, one HEI), all the advance is in well before 2500.
Old Sep 20, 2004 | 09:10 AM
76REDSTINGER
thanks
i was looking for the mechanical advance "allowed" w/ a stock
HEI dist
20 deg is optimal, most of the time, but ive heard that
you cant get that much from one
i just picked up a re-curve kit will play w/ that.
Old Sep 20, 2004 | 05:49 PM
glen242's Avatar
glen242
Originally Posted by 76REDSTINGER
thanks
HEI dist
According to the GM specs that I have, a #1112888 distributor as used on the L-48, has a maximum advance of 22* @ 4600. The #1103200 distributor as used on the L-82 has a maximum advance of 16* @ 2000.
Old Sep 20, 2004 | 07:16 PM
76REDSTINGER
thanks glen
R.
Old Sep 20, 2004 | 07:18 PM
76REDSTINGER
your low end should be good.
any compromise on the top end?
To 14 deg plus? for wot?
