call Comp and tell them you know there has been a problem..then ask if
was just a bad batch and see what they tell you.. they may ask for #
info so have it ready...LET us know
If you used their red lube pull the cam and use a lube that dose not drip off. (I used Crane lube)
I have a SB XE268 no problems. My only regret is that I didn't go bigger
okay 75 Stingray! don't start that should have went bigger stuff -
on second thought - go ahead -- how's your idle, vacuum accessories, power and the like? What do you think you would have gained/lost with a more-is-better cam? Knowing what you now know which cam would you select?
Well you know the sayings:
Bigger is better
More is never enough
Ha ha
I personally don’t think I’ll be happy until I get around 400 Hp to the wheel on a small block
I am actually very satisfied with my current setup.
I can only tell you the characteristics of my small block with the 268 I imagine the BBC would be slightly different.
With the heads, compression and th400 trans being the limiting factors in my setup I still had 231 hp at the wheels.
Vacuum accessories work normally with minimal additional pressure needed for the breaks, Before I taped the breaks I came to a stop now its not as sensitive but still works 100 times better then my 84 Trans AM with WS6. I don’t imagine there has been any change in stoping distance. Did I mention I also have a single plane intake.
