Is this engine streetable?
Old Sep 20, 2004 | 08:45 PM
Summerfun's Avatar
Summerfun
That Richmond is a great equalizer!!
Take the RPM's to 2000 on take off and run her hard through the gears.
If you have a lower numerical rear end, drive the RPM's a little higher
on take off.
You should not have a problem, but....you may or may not have the car clunking and shaking on driving in 6th at 1200rpm through the streets.....not sure about the small block.
You'll need a bigger carb with that duration too, speed demon at least but probably a mighty demon.....that thing will breath and would like to be fed.
If you do a high percentage of city driving, you might find that you will never get past 4th gear.....like I said she would clunk and shake at lower RPM's in 6th and maybe even 5th.
My 02....which will inevitably ripped apart and then we all learn
Old Sep 21, 2004 | 10:59 AM
SaltyNuts's Avatar
SaltyNuts
bump
Old Sep 21, 2004 | 03:30 PM
SaltyNuts's Avatar
SaltyNuts
Talked to AR Racing. He said that the 108 centerline is definately the LSA. He said that based on compression, heads, etc., the 406 does NOT have a weak bottom end. I asked him about right off idle power, and he said very responsive.
He did say that the 383 with the dart heads and a 106 seperation angle is more peaky (D or square port heads or something or other).
He also said that they will change cams/intakes no charge. Thus, I could request a milder cam in the 406 or 383 if I wanted.
Anybody have any thoughts as to the best way to go? Engine going into a 6-speed car.
Old Sep 21, 2004 | 08:39 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
One thing you do not have to worry about is low end power with a 406ci. You might be more worried about how many transmissions you are going to blow because there is too much torque.
The cam I have in mine is supposed to make peak power in the 6500 RPM and it will make more HP than torque, so you could say it is a high revving "peaky" motor untill you see the torque line, believe me it does not bog off the line
A 406ci can take alot more cam than a 350 or 383 but if you want to be safe you can go down a few degrees in duration and compensate with 1.6 rockers.
Old Sep 21, 2004 | 08:43 PM
GDaina's Avatar
GDaina
Retard, check your IM
Old Sep 22, 2004 | 12:19 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Not knocking you but if I were you I would go with a 112 LSA, mainly because it will idle better and be easier to tune. It will also make a little more low end and possibly top end power, if will suffer in average power. The 248 at .050 would not concearn me in a 406 or even a 383 for that matter. It is really not that radical.
