starting problems
Old Sep 20, 2004 | 09:40 PM
biggvette's Avatar
biggvette
Default starting problems
Hello everyone, Well my big block 427/435 has had starting problems since I purchased it. I am getting a click when i turn the ignition, but its not the battery or the starter. Also It doesnt matter if the engine is cold or hot its still clicks like a dead battery. My connections are also good. Everything is original and I am stuck. After awhile of clicks, it will just start like normal.
Old Sep 20, 2004 | 09:54 PM
R. Bruno's Avatar
R. Bruno
If you are sure the battery is good, then check the ground wire from the battery to the frame below the rear compartment. Make sure it is clean and secure. If this checks out, you might check the battery cables. Are they corroded? Frayed? Check the connection at the starter also.
Old Sep 20, 2004 | 10:10 PM
biggvette's Avatar
biggvette
I know it's strange, that's why i entered it on the forum. My cables are good and the connections are secure with no corrosion. I have put the charger on the battery and it really seems fine, even after a short time of clicks it will crank up. I had a problem like this with another car but it was my header to close to the starter and it only did it when the car was hot. So I am wondering if it's somewhere in the igition.
To starting problems
