Convertible top when down (help securing rattles)...
Old Sep 24, 2004 | 05:11 PM
Ken Lally's Avatar
Ken Lally
Default Convertible top when down (help securing rattles)...
Gang,
My car is very tight, no shakes, rattles or strange noises..... except coming from under my convert deck lid with the top down.
Does anyone experience rattles from the convertible top? Is it something to live with or does anyone have any solution to quiet rattles..?
Ken Lally
Old Sep 24, 2004 | 05:13 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I don't have that problem.. The only place that you can adjust the top is at the 4 bolts that hold the top..
Old Sep 24, 2004 | 05:16 PM
Fevre's Avatar
Fevre
Flow master 40's? Might try a towel or pillow between the deck lid and top to tighten it up a little.
olouieo's Avatar
olouieo
I don't hear any noise from the top been down. However I do hear noises everywhere else.
Old Sep 24, 2004 | 05:35 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
On my car there are 2 rubber bumpers that screw down from the deck lid to secure the top from rattling when down....you might want to check to see if you have them.
Old Sep 24, 2004 | 05:53 PM
mayberg's Avatar
mayberg
It may not be the convertible top. Check the trim and their fasteners. I had a loose screw on the rear interior quarter member.
Old Sep 24, 2004 | 06:17 PM
Mark70's Avatar
Mark70
I've also had some rattling from the mechanism pieces (rods, pivot, etc.), so you might check those parts for wear/play.
Mark
Old Sep 24, 2004 | 06:28 PM
RHD '68 L89's Avatar
RHD '68 L89
Originally Posted by Ken Lally
Gang,
Ken Lally
Ken, what condition are the latches in?
If they are loose with no load they may rattle.
Old Sep 24, 2004 | 06:33 PM
75rag4sp's Avatar
75rag4sp
My car is much more raddle free with the top down than it is up. i also recommend checking the bumpers under the decklid.
Old Sep 24, 2004 | 08:30 PM
RHD '68 L89
68's like Ken's and mine do not have the rubber baby buggy bumpers under the deck to hold the top in place
Old Sep 24, 2004 | 08:57 PM
joe73vette's Avatar
joe73vette
Mine is also a lot quieter with the top down, no rattles from back there. You'll have to experiment with pieces of cardboard to see if you can isolate it. Joe
Old Sep 24, 2004 | 09:17 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I have the following rattles (I am getting to it!):
gas lid - fixed it by lightly hammering the hinge pin
centre bezel where the bolt for the hardtop goes - it slides around a little
antenna - no idea why but it moves around a little
I would try masking tape on anything that moves around. Also check your rallye rims, mine are quite noisy. The four clip (original) are noisy apparently. The towel on top of the soft top when stored idea also sounded good.
Old Sep 24, 2004 | 11:52 PM
Wrencher's Avatar
Wrencher
I had the latch rattle problem when the top was down. I pulled the latches, set them up in a vise (carefully!) and re-staked the rivets that hold them tight. Worked great for me, and solved the problem.
Hans
To Convertible top when down (help securing rattles)...
