Frame Smoothing
Old Sep 24, 2004 | 10:08 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Frame Smoothing
Hello all,
I'm in the process of doing a body-off chassis rebuilt.
What techniques have many of you used to smooth the surface of your frame? Mine has pitting along the top rails along the rockers and along some of the crossmembers. Its not real deep, but deep enough to be seen after primer and epoxy.
Old Sep 24, 2004 | 10:30 PM
David Ey's Avatar
David Ey
high build primer
Old Sep 24, 2004 | 11:05 PM
NHvette's Avatar
NHvette
I didn't bother doing the frame, but I filled my windshield frame
in with a skim coat of JBweld. It worked well. Also, POR-15 has
a paste in a tube that will fill nicely. Not the POR-putty. I tried that
with poor results for filling pits.
Good luck
Old Sep 24, 2004 | 11:14 PM
i885744's Avatar
i885744
if its just cosmetic, a good quality body filler can be used on frame rails. Thats what the usually use on showcar chasis.
Old Sep 24, 2004 | 11:37 PM
mandm1200's Avatar
mandm1200
Looks like a few more coats and a lot more sanding. I am not sure why you didn't see this before painting. I assume you didn't sand the primer before hitting it with paint. The one nice thing about primer is hat it usally dries fast and sands easier than paint. One thing I found good to do is to use one color of base primer and then use a different color for build up. You will then know when you are getting close to metal when you sand down to the base color.
Old Sep 25, 2004 | 08:42 AM
gearheaddroppings
I have not painted the frame yet. I threw a couple of quick coats over some areas to get an idea of how it would look. I think that a combination of high-build primer and filler is going to do the trick.
Thanks for all of you help. I should have pictures of the chassis in a couple of weeks.
Old Sep 25, 2004 | 11:58 AM
MoneyPit's Avatar
MoneyPit
I would suggest visiting a body supply store, and asking for some Fiberall by the U-pol company. This stuf is amazing. It is hard as nails, literally. IF the pits are very deep. You will need to go to the metal. FIberal is very hard, waterproof, and can be shaped into anything. It comes in a large gun, and the hardener is pre measured. If the pits are not deep, I would suggest the same as above. You can use a high build primer, probably better known as a surfacer.
Old Sep 25, 2004 | 01:59 PM
76REDSTINGER's Avatar
76REDSTINGER
NO BODY FILLER !!!!!
frame flexes it will not hold
if you can find it get coal tar epoxy to coat frame you can put on up to 56 mils in one coat.......
but it is a one shot deal, if you dont recoat while the first is still tackey
do not add second coat
we use it at work to coat metel pipes that will be submerged for 20 yrs
R.
To Frame Smoothing
