New Fuel pump question?
Old Sep 25, 2004 | 02:17 PM
1970-Bronze's Avatar
1970-Bronze
Default New Fuel pump question?
Ok, I decided to get a performance pump for the 383.
The Stock pump has 3 connections: 1 - Tank, 2 - Return, and 3 - Carb.
The new pump only has 2. What do I do with the return?
Old Sep 26, 2004 | 08:42 AM
1970-Bronze
Anyone?
Old Sep 26, 2004 | 08:46 AM
Jack71's Avatar
Jack71
I just plugged mine up and don't have any problems vapor locking.
Old Sep 26, 2004 | 04:13 PM
Red_Shift's Avatar
Red_Shift
Okay, this is what I know about fuel pumps because I just read it in a book. Low-pressure pumps (4-10 psi and 110 to 140 gallons per hour) are intended for carbureted engines. High-pressure pumps (30 - 90 psi and similar gph) are more often used with EFI. Low-pressure pumps use a dead heading style fuel pressure regulator with no return line, while high-pressure pumps use a bypass style fuel pressure regulator with a return line. High-pressure pumps are constructed with closer tolerances and more costly production. They will tolerate more severe operation conditions and last lnger than low-pressure pumps.
Lastly, high-pressure pumps will work well in carbureted applications when matched with the correct bypassing fuel-pressure regulator. Maybe you took off a high-pressure pump and purchased a low-pressure pump.
Hopefully this will help
Old Sep 26, 2004 | 04:59 PM
PRESSURERAT's Avatar
PRESSURERAT
Just cap off the line unless you are worried about being NCRS correct. I have done this on several cars with no adverse affects.
Old Sep 26, 2004 | 06:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I capped off my return fuel line on mine. So far so good. Been about 4000 miles.
To New Fuel pump question?
