Fender Trim
Old Sep 25, 2004 | 05:03 PM
19Shark69's Avatar
19Shark69
Default Fender Trim
Ok, I have to install the small trim strips that attach to the top of the fender next to the wiper door. I have the clip...it is very narrow. No way will it fit around the fender and the trim plate. Do I grind down the inside of the fender? Or glue the thing is place and forget the clip?
thanks in advance
Old Sep 26, 2004 | 06:48 AM
Karfever's Avatar
Karfever
It takes two clips per side. I install the clips on the fender lip then CAREFULLY slide the flange on the fender trim under the clip between the fender and clip. Then screw the lip to the fender next to the wiper door. I guess you could glue then in place but it is a little too much Bubba for me!
Old Sep 26, 2004 | 10:23 AM
19Shark69's Avatar
19Shark69
Ok, I only have two clips for both sides....so I will buy two more. But looking at the clips and comparing how wide they are, and then looking at the front end where they clip, I done see how they will go around it. The fiberglass is at least a quarter of an inch thick and the clip looks like its about 1/8 inch thick. I put a new front end on the car a while back, so maybe I need to grind some of the fiberglass away from underneath the fender.
Old Sep 26, 2004 | 05:59 PM
Karfever's Avatar
Karfever
1/8 sounds about right. Either grind the rear fender edge (a real pita) or procure some wider clips.
Old Sep 26, 2004 | 06:20 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I still need to do this myself. I have never installed mine on my car. Any pics of installation would be greatly appreciated. I was wondering how these clips were installed.
To Fender Trim
