A/C Condenser ?
Old Sep 27, 2004 | 10:14 AM
Hvymtlc5's Avatar
Hvymtlc5
Default A/C Condenser ?
My 78 has had the A/C gutted and I'm in the process of putting everything back. Do I need to use the exact model condenser that was in the car (corvette condenser) or can I use another GM application if it will fit. If I can (use something besides OEM), any recommendations on what other condensers will work (impala, caprice, truck, etc).
Old Sep 27, 2004 | 10:28 AM
Pete76Shark's Avatar
Pete76Shark
Good question. I removed my condensor and had the radiator shop guy clean it and check it for leaks and then re-installed it. I would think the condensor is somewhat of a custom fit for our Vetts but I am not sure. Will be insterested in hearing what others have to say about this.
One thing for sure, if you get a condensor with more fins per inch you will have a cooler A/C system then the stock 78 condensor. But will it fit ??
Old Sep 27, 2004 | 12:40 PM
markdtn's Avatar
markdtn
Don't know for sure, but the stock cond. has lines that stay in the same plane. All the funny angles are with the other lines. Might go look at a 67-72 Chevy truck cond. It is similar in size I believe. Honestly, if it was me I'd bite the bullet and get a new one for a Vette. Try your discount stores it's only $161 from Advance for a correct fit.
Old Sep 27, 2004 | 02:31 PM
Wrencher's Avatar
Wrencher
I got mine from NAPA. Fit perfect and it is a larger capacity unit for better performance with r134a. $189.00 a few yeard back.
Hans
Old Sep 28, 2004 | 07:50 AM
Ganey's Avatar
Ganey
Originally Posted by Pete76Shark
Good question. ... Will be insterested in hearing what others have to say about this.
The Corvette has the compressor & condensor inlet & outlet on the correct side (right or pass.). Many do not. A mid 70s Chevy van condensor (connections on the correct side) might work.
Old Sep 28, 2004 | 11:38 AM
Hvymtlc5's Avatar
Hvymtlc5
Thanks - don't know a thing about A/C. Get the impression bigger is better..so I'll look for that in a condensor. I think the advice to get the right application is good, especially since it reall isn't that expensive to have the fit and capacity.
To A/C Condenser ?
