Ugh
Old Oct 9, 2004 | 04:38 PM
Schmucker's Avatar
Schmucker
Nuetral safety switch is easy to get to. Pull the side panel off the console on the passenger side, unplug it, put a wire with some alligator clips on the ends to jump it. When you get just nothing from the key on but the gauges and stuff come to life then I would think that it'd be neutral safety switch. If your gauges are all dead start checking the battery.
Old Oct 9, 2004 | 04:50 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
well.. here's what I checked.
starter connections are all good and tight.
went to the battery connections, they're all tight.
tried starting the car again, volt meter read 0
so it leads me to believe its the battery. I'll throw it on the slow charge
Old Oct 9, 2004 | 04:57 PM
Gordonm's Avatar
Gordonm
If you have a multi meter check the voltage at the battery. The nwork your way down the line. If your volt meter reads zero it does sound like the battery but it went pretty quick from the garage to the driveway.
Old Oct 9, 2004 | 05:11 PM
PRNDL's Avatar
PRNDL
At least 3 maybe 4 times I had problems starting and thought it was the starter, alt, or other, and every time it was the battery (Or connections to the battery). You'd think I would learn, right?
Old Oct 9, 2004 | 05:18 PM
Corz's Avatar
Corz
I drove it around the block.. I just put the cyl head back on. I'm gunna check the voltage at the battery in about 30 seconds..
Old Oct 9, 2004 | 05:24 PM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
I would bet that the fuseable link took a crap. The flex coating might be intact, but the link blown within.
Worst case you can jump the posts on the starter, and check for crank that way.
Old Oct 9, 2004 | 05:46 PM
Corz's Avatar
Corz
battery reads 15 volts
starter is reading 15 volts..
i cant find the NSS to save my life
but I think thats the problem
Old Oct 9, 2004 | 05:51 PM
Corz's Avatar
Corz
i wonder if anyone local will have it
Old Oct 9, 2004 | 06:20 PM
Gordonm's Avatar
Gordonm
In the meantme just run a jumper across the two purple ones to see if it is the problem. If you want to check and see if you are getting 12 volts at the starter when you hit the key. You will need two people for this. Check the purple wire when you hit the key. This is the one tha tgives juice to the selonoid. If no juice probably the NSS
Old Oct 9, 2004 | 06:24 PM
CGGorman's Avatar
CGGorman
Take the connections loose at the battery and reinstall. Every time I've had or heard of a sudden no-crank, it's been the connections at the battery. Sometimes they seem tight and aren't sometime they look clean and they aren't. I'd bet my hat on connections.
Old Oct 9, 2004 | 06:30 PM
Corz's Avatar
Corz
Check the purple wire when you hit the key. This is the one that gives juice to the selonoid. If no juice probably the NSS
its the NSS
no one carries it locally either
Old Oct 9, 2004 | 06:34 PM
Gordonm's Avatar
Gordonm
Jump it! That switch also controls the backup lights. That is what the other 2 wires are for. I would not figure any one local would have it.
Old Oct 9, 2004 | 07:04 PM
  #33
Corz's Avatar
Corz
i just checked everything out with my dad, the nss does have power
same with the battery..
and one side of the solenoid (outside, orange wire) reads 15v
the inside reads ZERO. so...
I'm not sure if both wires should be giving juice, or if only one should
Old Oct 9, 2004 | 07:11 PM
  #34
stpman's Avatar
stpman
On the solenoid the three terminals are
1 the large terminal with power from the battery
2 The small terminal 'R' with the power from the ignition switch (key in start position)
3 The small terminal 'S' with the yellow wire that goes to the coil, bypasses the resistor wire when starting
Steve
Old Oct 9, 2004 | 07:22 PM
  #35
Gordonm's Avatar
Gordonm
2 The small terminal 'S' with the power from the ignition switch (key in start position)
3 The small terminal 'R' with the yellow wire that goes to the coil, bypasses the resistor wire when starting
Steve
The yellow wire R should have 12 volts with the key in the ON position the purple wire S should have zero. With the key in the start they both should have 12 volts.
On the NSS you should have 12 volts in and 12 volts out when you are in park or neutral. In other gears you will have 12 in but nothing out.
Old Oct 9, 2004 | 07:24 PM
  #36
Corz's Avatar
Corz
thanks Steve
  #37
stpman's Avatar
stpman
If the yellow wire has 12 volts in the ON position then the resistor wire to the coil would be always bypassed. The yellow wire should only have 12 volts during starting.
I had the 'R' & 'S' backwards in the above post now corrected
To Ugh
Old Oct 10, 2004 | 06:57 AM
  #38
comp's Avatar
comp
you running now?????
Old Oct 10, 2004 | 06:59 AM
  #39
Corz's Avatar
Corz
no... sun's not even up yet
Old Oct 10, 2004 | 07:43 AM
  #40
jerome french guy's Avatar
jerome french guy
Image are better than words!
Starter page1
Starter page2
Starter page3
