First official shake-down run.
Old Oct 10, 2004 | 11:10 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default First official shake-down run.
Just got back from my first official venture out of my driveway with my rebuilt 454 & M-22. I got the brakes bled today (alone as always) and took her down the street to fill up the tank.
I got a sputter starting at 2500+... may be the plugs fouled due to the excessive idling, could be the carb needs tuned too. Any other ideas? Also got some backfiring thru the exhaust during a down-shift. Maybe carb running too rich.
Oil pressure--- @2500rpm 35psi
temp---- fans held the temp @<195
ammeter +10
It ran pretty good and I surprised myself that it would run this good with me doing all the assembly from the ground up.
I'm just estatic that I got all this done before the snow flies soon. My original plan was to just have the engine swap completed and not necessarily road worthy. I really can't do much in the winter around here...my garage is too cluttered with my wife's crap and too cold.
Old Oct 10, 2004 | 11:14 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Congrats Len. That is the news we have been waiting on. So now are you gonna take it out for a nice Sunday cruise today? I believe I would have to make some miles dissappear, just to make sure that everything is alright. Wink, Wink.
Old Oct 10, 2004 | 11:21 AM
Summerfun's Avatar
Summerfun
Congrats!!
Isn't that oil pressure a bit low at 2500??
Old Oct 10, 2004 | 11:37 AM
Brettmc's Avatar
Brettmc
Congrats!! Good feeling knowing you did it all. Your carb probably does need a tune. But get rid of that 3310 and put one of your DPs on it. Also, spend about $40 and get an O2 sensor welded in your header collector. It's really the best way to tune a carb...any other way is just guessing.
Old Oct 10, 2004 | 12:00 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Originally Posted by Summerfun
Congrats!!
I thought the guidline was 10psi/1000rpm?
Old Oct 10, 2004 | 12:01 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Thanks guys, I'm gonna re check the valve lash now. Seems a little loose. 0.030?? I had it set at 0.026 when I built her.
Cam spec's said to start loose & re-tighten to 0.022.
Old Oct 11, 2004 | 12:00 PM
CGGorman's Avatar
CGGorman
Congratulations!! Sounds like you're about two weekends (by my work schedule) from a full-on drive! I'm excited for you and always look for your updates. I'll miss them when you're finally "done".
Old Oct 11, 2004 | 01:14 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Congrat, Now drive before it's -10 degrees.
Old Oct 11, 2004 | 02:41 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Actually we went for a little longer run later yesterday. About 15 miles round trip. I didn't want to go too far, I was worried about the miss above 2500.
I set the valve lash today and tried to adjust the carb. I also put new plugs in, the old ones had a lot of black deposits. (too rich?)
That seemed to help a little. Still getting a little miss and a little backfire thru the pipes of 3-2 downshift.
I guess it's running good enough for most, but I won't be happy until she's purring in all gears.
Still having problems with the reverse shift linkage too.
Old Oct 11, 2004 | 02:44 PM
Z-man's Avatar
Z-man
Congrats!!
That's got to be a good feeling. How's the transmission linkage on the road? I'll bet it will loosen up after 500 or so miles...
Old Oct 11, 2004 | 03:25 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
1-4 shifts are much better than my old Comp+ shifter. Short and, I hate to use this word, crisp! For lack of better description. No problems with 1-4 out on the road. I just can't go backward.
To First official shake-down run.
