I had major fuel starvation during turning at anything less than 1/3 tank. My first fuel pump only lasted a year and I think the fuel starvation was a factor.
I had a custom aluminum tank built with baffles and a sump. It is now impossible to get airbubbles in the line (I've tried).
I put a 90 Bronco internal fuel pump on my 68, just had to make to top hole a little bigger and then the whole thing dropped in. The return line returns to self contained reservoir so there is always fuel returning to the pump suction side. If yours is a 79 it may even have a bigger hole for all the stuff on top.
Happen to have any pics of that set up? Sounds like a winner for EFI.
One of the people at S&P told me that they just did an LS1 conversion, they used a pump that mounts to the sender from a 82 vette, went right in and works fine as 78+ uses the same fuel tank, also read the same thing at corvettefaq.com. Heck of an idea if it works well.
Thanks guys. Sounds like it might just be a "keep you're fingers crossed and hope for the best" type situation. I'm wondering why some have problems while others don't?
I find with my '72 and TPI, and frame mounted pump, with filter B-4 the pump on the suction side, that it's about the best solution...but that does nothing for a hard right turn....
I'd also be interested in seeing pics of your setup. Hopefully someone will host them...
