KZF ** Olds 442/Hurst
CZF ** Monte SS
BRF ** GN/T-Type/Turbo Regals
OZ ** Hurst Olds
OM Olds 350 Diesels
OG Olds 307
BY V-6 252 Cars
AA and AP Cadillac's
Transmissions marked "**" have a special (better for performance) valve body, plate, 1-2 servo, 3-4 servo, 2-3 intermediate servo, and governor.
These codes can be found on the passenger side of the transmission near the output shaft. Sometimes they are hard to read due to the catalytic convertor getting in the way.
The valve body itself will have the first two letters painted on it. Be careful because the paint comes off easily. The special valve bodies usually have a purple strip on them also.
There are more codes that just that, but it has the important ones. The ID tag is at the end of the transmission near the tail housing. It is rivited on there with two rivits. Just look for those letter groupings.
