Pulley alignment issues.....
Old Oct 23, 2004 | 12:59 PM
1970-Bronze's Avatar
1970-Bronze
Default Pulley alignment issues.....
Ok, I'm at a loss here.....looking for suggestions.
Ok - New 383 stroker installed.
Using stock pulleys.
Power steering lines up perfect. Used straight edge to verify.
Water Pump is off. Edlebrock 8810 pump. I measure 5 3/4" and web site says it's suppose to be 5 5/8".
Original pump measures 5 5/8".
I don't think I can live with 1/8" - can I?
Ideas?
Old Oct 23, 2004 | 01:22 PM
1970-Bronze
Ok, re-measured the new water pump and it is 5 5/8" like it should be but I'm still 1/8" off from the crank.
Ok, if the PS lines up what's wrong?
If the HB was 1/8" further out I would have thought it would have makde the PS 1/8" off....?
Thoughts?
Old Oct 23, 2004 | 05:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I don't think that 1/8 is gonna be that critical. Hopefully someone else will chime in and give some more advice.
Old Oct 23, 2004 | 08:00 PM
Red 69's Avatar
Red 69
Pulley alignment is critical for long wear and without problems. Even if you use the proper HB installation tool and mount it correctly there can be a misalignment. Jeg's sells a water pump shim kit that might solve your problem.
http://www.jegs.com/cgi-bin/ncommerc...99&prmenbr=361
Old Oct 23, 2004 | 08:43 PM
1970-Bronze
The WP pump pulley is too far forward, so shimming it would only make it worse.
Old Oct 23, 2004 | 11:45 PM
Brettmc's Avatar
Brettmc
Shim the crank pulley and the power steering bracket??
Brett
To Pulley alignment issues.....
