clanking sound when starting
Old Oct 24, 2004 | 01:35 PM
tatersalad's Avatar
tatersalad
Default clanking sound when starting
When I start my 80 there is a clanking sound when you first start it. A mechanic told me the starter and flywheel needs replacing. Yesterday when I changed the transmission fluid the clanking sound was much more pronouned when I first started it, which leads me to believe it's actually the torque converter clanking, and not the starter/flywheel.
Anyone had a problem with a clanking torgue converter?
Old Oct 24, 2004 | 01:43 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Can't remeber if there is an inspection plate on the bell housing but if there is, you might want to pull it off and have a feel around for metal parts floating around inside.
Does the clanking go away as the engine/tranny warm up?
Old Oct 24, 2004 | 02:05 PM
tatersalad's Avatar
tatersalad
Yes, it's only when you start it, and is more pronouned when everything is cold.
Everything seems fine while driving.
Old Oct 24, 2004 | 03:33 PM
Steve's74's Avatar
Steve's74
Check the torque convertor to flywheel bolts if it's an automatic.
Steve
To clanking sound when starting
