Backfiring ??
To recap:
Saturday I will:
Pull and inspect plugs,
Install new intake gaskets
Install new header gaskets
Install new valve cover gaskets
Adjust valve lash
Reset timing
Re-tune carb
So if y'all think of anything else, lemme know.
Thanks for any help y'all can give!
carbon
If it looks bad on all of them you might just need a hotter set of plugs. I had a little misfire in one of my rides a few months ago and when I stepped up the heat range, it went away.
-Mark.
A few things to do:
First, don't retard the timing - this will make your heating problem worse and the hesitation worse. Set your timing up for 36 total advance; this will most likely put you at about 16-18 degrees advanced. You need this much advance with your setup. Then, run your vacuum advance off of a manifold vacuum source instead of the ported source. This will give you a bunch of advance and will reduce engine temp along with improving off-idle and part throttle response.
The Edelbrock carbs are jetted very lean, but tend to work okay with stock exhaust manifolds. With your headers you need to bump the jet size up about 2 sizes. This will take care of the stumble and further reduce the tendency for pinging, allowing the 36-degree total timing setting.
