Steering lash adjustment
Old Nov 7, 2004 | 09:53 AM
jdmick's Avatar
jdmick
Default Steering lash adjustment
As I understand it there are two adjustments I can make on my steering sector. The screw on the bottom first (after you back out the top one about 3 turns) and then the one on the top. The Haynes manual gives a lengthy decription involving pulling the pitman arm, disconnecting the steering shaft, and using a torque wrench that is much more sensitive than mine. On my old truck the adjustment is to simply bottom out the screw and back it off about 1/4 or 1/2 turn. Would something like this work on these two adjusters or ? Thanks!
Old Nov 7, 2004 | 10:15 AM
75 Hot One's Avatar
75 Hot One
If you don't want to go by the book method, the specified preload is obtained roughly by just snugging up the adjusting nut & screw until light resistance is felt. That should put you pretty close.
Old Nov 7, 2004 | 10:50 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
This is news to me and very interesting. Nobody ever talks about a second adjustment. I have adjusted the top screw about 3 - 4 times over 24 years and the last time it seemed that i ran out of adjustment.
I thought Jim Shea had an article on how to make the adjustment but can't find it.
EDIT: Yep, its all there on corvettefaq.com I guess the second adjustment is the worm gear adjustment on the steering column side. This one i have never messed with.
Old Nov 7, 2004 | 11:25 AM
jdmick's Avatar
jdmick
I can't find the bottom one either! The manual talks about one for the "early models" for which they show a box that looks like mine on the top. It says "the worm bearing adjuster is the large lock nut and hex located at the bottom of the steering box". It doesn't make mention of this for the "later models" so I'm not sure when the cutoff is. For the later models it talks about adjusting the "thrust bearing preload" first and then the "over center preload". So it would seem that either gearbox should have two adjustments .
Old Nov 7, 2004 | 12:42 PM
Jim Shea's Avatar
Jim Shea
This paper covers both adjustments. If you are carefull, you can make the adjustments with the gear still in the car.
http://www.corvettefaq.com/c3/GearAd...-Rev21FE04.doc
Old Nov 7, 2004 | 12:44 PM
jdmick's Avatar
jdmick
I found the article by Jim Shea too. Looks like exactly what I needed. Who would guess that big nut around the steering column is an adjustment. Sounds like he really knows his steering! Thanks.
Old Nov 7, 2004 | 01:14 PM
LYLE's Avatar
LYLE
The big nut is a lock nut the large cast hex is tightened the thin big nut is the lock. It is adjusted like a front wheel bearing. If the bearings or races are worn would be the only time an adjustment is needed.
To Steering lash adjustment
