vin number question
Nov 11, 2004 | 01:55 PM
vin number question
Need alittle help from you Guru's out there. My 74 vin number is 1Z67J4S401094. I understand all of it, however, I do not know the approx date it was built. Can anyone tell me by the last six numbers when it came of the line in St. Louis?
Nov 11, 2004 | 02:05 PM
There was some kind of date calculator online, don't know where...maybe someone has it.
Nov 11, 2004 | 02:07 PM
September, 1973... September cars were 01251 thru 04111
OOPS ! Correction......August'73 Sorry 'bout that guys
Nov 11, 2004 | 02:09 PM
Thanks Larry! Is there someplace online I can get this information?
Nov 11, 2004 | 02:14 PM
I got it from the Corvette black book. You can get one from almost any corvette supply house like Eckler's or Zip or.....
Nov 11, 2004 | 02:21 PM
There should be a trim tag on the driver side door hinge pillar that give codes for exerior paint color and interior trim. In the upper right of the tag is a letter and number that represents a month and day and should be within a few days of when your car was completed. Also, there should be a date on the vehicle certification label near the drivers door latch that gives month and year. September 73 would be B.
Nov 11, 2004 | 02:24 PM
I went to the NCRS-Wisconsin web site. They have a "birthday calculator" and according to it your build date is Aug. 30, 1973.
Hope this helps
Nov 11, 2004 | 02:25 PM
Opps... I mis-read.. Your car is August 1973. 1094 is a late August car.0125 was the last car built in August 73
Nov 11, 2004 | 03:15 PM
I went through this before, and the birthday calculator and calculating
from the first/last VIN were off by days.
By far, the most accurate way is to go with the date on the
trim tag and add 2-3 days for vehicle completion.
Here is a good thread that I started years back ....
http://forums.corvetteforum.com/showthread.php?t=347896
Here is a quote from that thread ...
"According to the NCRS calculator, mine was built 3 days after the first owner bought it!!??
" -joe74
Nov 11, 2004 | 05:06 PM
Aug 20, 1973
Thanks guys. I knew the Guru's on this site could help me. I was a Junior in HS when it came off the line.
Thanks again.
