Differental Fluid Question
Old Nov 12, 2004 | 11:09 AM
JIM PORTER's Avatar
JIM PORTER
Default Differental Fluid Question
I Have A 75 Vette And Am Going To Change The Differnetal Fluid And Add The Gm Additive However I Have To Order The Additive And Differental Gasket And I Have An Event To Attend This Weekend. My Fluid Is Low Due To A Leaking Differental Gasket. I Have Some Valvoline 80-90 Fluid And Some Crc Additive For Posi-limited Slip Can I Use This Stuff
This Weekend? My Rear End Is Limited Slip And It Reads Limited Slip Fluid Only. Will The Crc Posi-limited Slip Additive Hurt It?
Old Nov 12, 2004 | 11:41 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
If the Crc stuff meets the GM spec it should work fine. Just by it's title it sounds like the right stuff. You shouldn't have any problems. The tag on the diff. housing just means you have to use the additive.
Old Nov 12, 2004 | 12:22 PM
JIM PORTER's Avatar
JIM PORTER
Does The Gm Multipurpose Differental Fluid Need The Additive? And Will The Gm Posi Additive Mess Up The Limited Slip Rear End ?
Old Nov 12, 2004 | 12:33 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the gm posi additive is made especially for the limited slip differential
Old Nov 12, 2004 | 12:55 PM
hdvettes's Avatar
hdvettes
If you can find Torco products their GL6 rated gear oil works very well as it is designed for positraction. We use it in all of our Corvette rear ends. Both on the street and road courses.
Mike
To Differental Fluid Question
