instrument gage light
Old Nov 22, 2004 | 11:18 PM
telk's Avatar
telk
Default instrument gage light
One of the instrument gage lights on my 69 is not working. Have power going to the socket but when I put a bulb in it doest't work. Bulb is good and even tried putting some foil in to tighten contact area. Any opinions? F****d with for a couple of hours with no results. Thanks
Old Nov 23, 2004 | 01:28 PM
carupano's Avatar
carupano
I had similar problems and here is how I am in the middle of doing mine.
I had some of my instrument panel light bulbs missing and some I thought were burnt on my 1979. When I took the panel out, I noticed that the ones I thought were burnt were not. The problem was with the printed circuit connectors. It has blown the connection to those bulbs. In order to fix those connections, a friend of mine suggested I buy a kit that is used to repair rear window defogger. It is liquid copper. It is easy to use. It worked very good. It took care of the problem. While you are there, it is not a bad idea to replace all bulbs with new ones. I hope this can help.
Good luck!!
ps. Change the sockets also.
Old Nov 23, 2004 | 08:29 PM
Motor City Vette's Avatar
Motor City Vette
Good luck!!
Can you explain further what you mean by "printed cicuit connectors"? Where are they located, etc. A couple of my lights don't work in my center gauge cluster on my '70 and I'd like to fix this, too.
Thanks!
Old Nov 23, 2004 | 08:39 PM
i885744's Avatar
i885744
you don't have printed circuit connectors on a 69. The sockets the bulbs go into provide the power. If you have 12v + going to the socket you either have a bad bulb or a bad ground. The socket itself provides the ground. I'd clean the contact area and try it again.
Old Nov 23, 2004 | 08:46 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Nov 23, 2004 | 11:50 PM
telk's Avatar
telk
So you're saying that the bulb won't light unless socket is grounded on the instrument panel with those little prongs?
Old Nov 24, 2004 | 05:35 AM
Larry B.'s Avatar
Larry B.
I had a couple that were like that and it was just a matter of a good clean ground between the socket and instrument housing.
Old Nov 24, 2004 | 07:54 AM
Edzred72's Avatar
Edzred72
YES!!!
Eddie
Old Nov 24, 2004 | 12:01 PM
Deep sea vet's Avatar
Deep sea vet
Default No dash lights
What would be the cause of all the lights not working. I changed a blown fuse and it keeps blowing them.
Old Nov 24, 2004 | 12:55 PM
markdtn's Avatar
markdtn
You have a short. You can try removing all the bulbs and putting them back one at a time, but I'll bet you have one that is broken and touching a ground. Either that or a wire melted somewhere.
Old Nov 24, 2004 | 04:16 PM
Motor City Vette
Anything special you used to clean them with? Just a wire brush?
To instrument gage light
