Help with C3 ID
Old Nov 23, 2004 | 04:58 PM
2TONE82's Avatar
2TONE82
Default Help with C3 ID
Requesting help with a project…the goal is to be able to accurately determine the year of a C3 at a distance, say three feet, assuming the car is in factory/stock configuration.
The cars I’m having problems with follow:
70 and 71 both have clear turn signals, 72 has amber turn signals. Are there any other styling clues that will tell these model years apart, especially the 70 and 71?
75 and 76; only difference is the 76 doesn’t have the vents on the rear deck behind the back window, correct?
76 and 77; I know 76 was the last year of the “Stingray” fender badge, did the 77 have crossed flags on the fender or nothing al all?
I often refer to the 1978 to 1982 rear end body style as "fastback", any ideas of a similar term for the 1968 to 1977 rear end body style, "notch back"?
Also looking for a few pictures. Need one of the rear deck of a 75 showing the vents and one of a 76 showing no vents.
Thanks for your help
Old Nov 23, 2004 | 05:06 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
71 has front RH & LH egg crate grill mounted with philips head screws on lower trim edges. 70 had cast in posts with retaining clips.
Bullshark
Old Nov 23, 2004 | 05:12 PM
2TONE82's Avatar
2TONE82
Thanks! Thats exactly the type of detail I'm looking for...
Old Nov 23, 2004 | 05:15 PM
1970 Dave's Avatar
1970 Dave
It's getting harder to use this as a guide as all the repoduction pieces are the 71 and 72 style--originally the 1970 eggcrate louver had chrome only on the horizonal edges and the first vertical edge while the 71 and 72's had both horizontal and vertical chromed. If you check the 1970 Registry of Juliets you can see a example of the difference.
SEMPER FI--1970 Dave
Old Nov 23, 2004 | 05:33 PM
Larry B.'s Avatar
Larry B.
77's early had Stingray badges then they were replaced with cross flags and the alarm switch was moved from the front fender. But.... I have a friend who has all three... Stingray, crossed flags and the alarm switch. Nothing is for cetain with these cars. Now... 68's have unique door opening thumb buttons that are in a recessed pocket in the door. 68 and 69's have black fiberglass rocker panel swith an aluminum trim strip along the top. Get a copy of the "corvette black book" for all the little details.
Old Nov 23, 2004 | 05:51 PM
dragonracer's Avatar
dragonracer
Check out this site, lots of info
http://100megsfree4.com/corvette/
Old Nov 23, 2004 | 06:17 PM
Missileman's Avatar
Missileman
Hate to throw a wrench in the works...
Late 71 (possibly the last two months of production) turn signal lenses went amber.
Old Nov 23, 2004 | 09:19 PM
72LS1Vette's Avatar
72LS1Vette
You guys are all assuming that the cars have retained their stock parts for the last 30+ years. Don't forget the Designs by Bubba creations and the rare crash repair.
Rick B.
Old Nov 24, 2004 | 12:37 PM
Roadster71's Avatar
Roadster71
I thought it was the first 2 months that where clear.
Old Nov 24, 2004 | 12:43 PM
Missileman's Avatar
Missileman
In my experience (judging, restos) the later ones went to amber. A good indicator is the bulb underneath. If it had an amber lens a clear bulb was used. Most bubba's would change a lens but not think about bulb color.
Old Nov 24, 2004 | 05:23 PM
hunt4cleanair's Avatar
hunt4cleanair
The styling for the 68-77 flowed from the "sugar scoop" effect of the XP-819 design car...
"Additional modifications had to be made to transform the Mako Shark II concept car to a Corvette production vehicle and accommodate real world driving conditions. The view was impossible out of the rear slit of a window located in the Mark Shark ducktail and the sugar scoop treatment of the XP-819 concept car was adopted for the C3. "
So in contrast to fastback...it was called sugar scoop and was terrible in terms of aerodynamics. Racers used the convertibles to improve the aero package.
Old Nov 24, 2004 | 07:39 PM
HDFLH67's Avatar
HDFLH67
Rear letters on a '75 are individual in recessed indentations. I believe the '76 is a one piece.
Old Nov 25, 2004 | 01:06 AM
FinnShark's Avatar
FinnShark
That's true, but many '75 bumbers have been replaced with -76 bumbers and rear lettering if rear bumber was damaged, I have one example of this...
'76 had different steering wheel than '75. '75 had still this "classic" 3-spoke wheel, while '76 had one year only 4-spoke (vega?) steering wheel.
Was all '77 gas gap without any emblem? Gas gap was totally straight without a "pocket" for emblem?
'80, '81 and '82 had all different emblems! '80 with chrome edges, '81 same as '80 with black edges and '82 "shorter" with black edges.
These are few details that I use to figure out the model year!
Old Nov 25, 2004 | 11:19 AM
Glassbowtie77's Avatar
Glassbowtie77
77's never had Stingray emblems on the fender unless someone put them on afterwards or they are not the original fenders. Very early 77's had no fender flags and the alarm key on the fender, early to mid-year had flags and alarm key on the fender, and late 77's had flags on the fender and the alarm key was in the D/S door lock.
To Help with C3 ID
