From: San Diego - Deep Within The State of CONFUSION!
Modern Starters (mini hi-torque)
When I built my stroker and installed it, I used a mini hi-torque starter from a local vendor I've used for years. It was really noisey and I returned it, because it always sounded like an old GM starter that needed to be shimmed.
I've had the replacement starter in there for a year now, and I'm tired of it's noise too although it always starts OK. It sounds no better than the first one. It came with new bolts (they said that I should have been given new bolts the first time too.)
The vendor claims that these units he sells have a different number of teeth on the gear than an OEM starter does, and the noise is normal.
I haven't tried shimming it although it may be a good idea?
The reason I'm posting is that I've seen a couple of people here in this forum say they are running modern hi-torque starters from late model vehicles. I'd like to find out what part numbers and where to get them.
I'm running a GM (Delco) starter out of a late model pickup. I forget the exact year, but it's the last year of the 454 before they went to the vortecs. mid 90's. One important thing about the late model starters is that they use metric bolts so your stock 3/8" bolts will be loose. I went to the hardware store and got 3/8" inner diameter thin wall brass tubing. I used that as a sleeve for the bolts and it made a nice tight fit. I didn't have to use any shims at all and it starts great. Sounds like a late model car starting.
Sounds like just what I want! The bolts that I have in this (2nd) starter are Metric I think ... it's just a generic mini starter. But I remember when they gave me new bolts with this unit, they were slightly different than the OEM ones so they must be Metric.
BTW you said yours was from a BB. Are they interchangeable with a small block starter?
Anyone have a part number?
Yep, small and big blocks use the same starter. Don't have a PN, but just go to any parts store and have them find it. Look for a 3/4 ton pickup (2500 series, I think). Last year you see "454"... should be in the mid nineties. That's the one. If they come back with a huge heave monster of a starter you're too early. This one is tiny and weighs less than 10 lbs.
I put that starter on my 1979 about five years ago because of a heat-soak problem. It is SB and BB compatible. You can see the various adaption holes in this pic. It has not failed to this day. Why fool about with compromises? Premium price but premium fit. I don't like being stranded....
Thanks for the tip, Zwede! OK, here's a question. How can the same starter fit flywheels with different number of teeth? Are they just "close enough" ??
You can see the different mount hole configurations in my pic. The install instructions are very clear. This is a GM part designed to fit a GM vehicle of the C3 period. Why fool about with aftermarket?
Originally Posted by Z-man
From GM parts online:
